rockbrain
Member since January 2022
Post by rockbrain on May 7, 2023 13:39:53 GMT -5
Should I cut this with the seam that's on the side or perpendicular to it?
Post by stardiamond on May 7, 2023 15:27:36 GMT -5
I don't collect or have specimens, I have inventory. If you are planning to slab the piece make a test cut with your best guess and then adjust fort the second cut.
khara
Member since September 2022
Post by khara on May 7, 2023 16:35:42 GMT -5
@currentlyrockhoundin has a video on this. Can’t remember the name but it’s one of his earlier ones, scroll way towards the beginning of his content.
rockbrain
Post by rockbrain on May 7, 2023 16:43:17 GMT -5
I don't collect or have specimens, I have inventory. If you are planning to slab the piece make a test cut with your best guess and then adjust fort the second cut. I already have a job and a business. All my inventory is at my shop and it has to do with air conditioning and metal work. This is a hobby for me and this is a specimen. I appreciate anytime anyone takes the time to read and comment. I guess I can't say the best guess advice sucks because you qualified it. Thanks.
Post by Deleted on May 7, 2023 17:09:41 GMT -5
@currentlyrockhoundin has a video on this. Can’t remember the name but it’s one of his earlier ones, scroll way towards the beginning of his content. Thank you for the mention. I do have a video on this!
rockbrain
Post by rockbrain on May 7, 2023 19:15:10 GMT -5
Thanks khara and @currentlyrockhou din. Turns out it was hollow. I did watch the video first.
Post by HankRocks on May 7, 2023 21:57:37 GMT -5
The crystals have the look of being Smoky. Difficult to tell for sure, I always look at the tips of the points, if they are smoky it will show up there and not be picking up color from the base material. Same works for the Amethyst Choyas, the crystal can pick up the blue gray from the base agate and appear to be amethyst.
khara
Post by khara on May 8, 2023 3:36:12 GMT -5
That’s cool! Are you going to polish the cut face?
rockbrain
Post by rockbrain on May 8, 2023 8:19:36 GMT -5
Yes, I already did it. Pretty easy when they're this small.
chris1956
Member since July 2022
Member is Online
Post by chris1956 on May 8, 2023 8:32:12 GMT -5
Looks like you cut it just right. If you had cut perpendicular to that cut you would have ended up with two little "caves" that you couldn't see the end of.
rocknewb101
Member since October 2022
Post by rocknewb101 on May 9, 2023 12:52:26 GMT -5
That's gorgeous! Love the color inside. I have several that I cut that have real pretty clear crystals - love the smokey. I always struggle with knowing the best way to cut my rocks. This video is helpful! Thanks for sharing.
wargrafix
Member since June 2023
Member is Online
Post by wargrafix on Jun 11, 2023 10:55:19 GMT -5
Looks like you cut it just right. If you had cut perpendicular to that cut you would have ended up with two little "caves" that you couldn't see the end of. I have a few pre cut ones that are like that. Not a big fan of the cave cuts. He cut it perfectly
Post by aDave on Jun 11, 2023 13:05:25 GMT -5
Turns out it was hollow. I did watch the video first. So, out of curiosity, how did you orient the "seam" when you cut it? Did you cut directly through it? I watched the vid as well, and you only had one ridge to work with that I could see. I'm still confused.
rockbrain
Post by rockbrain on Jun 11, 2023 22:21:00 GMT -5
aDave I cut it perpendicular to the seam.
JR8675309
Member since August 2019
Post by JR8675309 on Aug 8, 2023 4:50:09 GMT -5
I've always cut from the "pimple" to the "dimple" as you did with this one.
