Post by stardiamond on Jun 5, 2023 19:19:15 GMT -5
I buy heel slabs because beside the slab there can be a bonus slab underneath. My slab saw skills could be better. I glued the face to a board with water glass and waited three days and then put the board in the vise, aligned the blade with the board and turned the cross feed 7 turns clockwise and cut. I got a .35 even slab. Better too thick than too thin. The faced piece I bought. The other side after the cut. The rough side of the bonus. The flat side of the bonus I'll trim off the knife edges and bad areas and the level the high point marked in yellow which is .4 inch. I can choose either what I marked or what shows up after flattening. In any case the yield for the piece is increased by another preform.
Post by stardiamond on Jun 6, 2023 16:34:46 GMT -5
The bonus slab preform fractured when I was trimming knife edges. One of the preforms I laid out on the faced slab fractured. I did get one excellent preform.
aGates
Building a silver studio
Member since January 2021
Post by aGates on Jun 6, 2023 18:19:40 GMT -5
The triangle piece is dank! I hope it's the solid one? stardiamond
Post by stardiamond on Jun 6, 2023 18:29:17 GMT -5
I'm hoping. I thought all three were solid. The only problem area was in the yellow and I moved the design away from it.
Post by stardiamond on Jun 8, 2023 15:02:13 GMT -5
