choochoorocks
Rock hounding
Member since April 2020
Post by choochoorocks on Jun 7, 2023 19:49:24 GMT -5
Hi,
I just got a used MK 101 tile saw. The blade on it looks pretty thick. I'd like to replace it with a new blade. Any recommendations? I've read that the MK 225's quality seems to have gone down. Or should I get a MK 301?
TIA!
Post by Starguy on Jun 7, 2023 22:23:47 GMT -5
hypodactylus
Member since July 2021
Post by hypodactylus on Jun 8, 2023 10:14:51 GMT -5
I have a tile saw (8" blade) that I use to cut/trim/slab rocks. I once tried the 'BD-305 Agate Kutter' blade and determined that it wasn't really much (if any) different than a much cheaper blade. So, I have since been buying and using 'QEP Black Widow' blades for much less money. Keep in mind that tile saws tend to run at high RPMs and not all diamond blades are rated for high RPMs. For example, it appears that a CabKing runs at around 1500 RPM while my tile saw allegedly runs at 4400 RPM. The blade Starguy posted looks interesting. I wonder if it is usable on a high speed saw.
Post by aDave on Jun 8, 2023 11:16:00 GMT -5
Hi, I just got a used MK 101 tile saw. The blade on it looks pretty thick. I'd like to replace it with a new blade. Any recommendations? I've read that the MK 225's quality seems to have gone down. Or should I get a MK 301? TIA! In another thread, member brybry took the advice given by hypodactylus (QEP Black Widow), and it looks like he is also pretty happy with the blade. Just sayin'.
Post by Starguy on Jun 8, 2023 14:34:23 GMT -5
I have a tile saw (8" blade) that I use to cut/trim/slab rocks. I once tried the 'BD-305 Agate Kutter' blade and determined that it wasn't really much (if any) different than a much cheaper blade. So, I have since been buying and using 'QEP Black Widow' blades for much less money. Keep in mind that tile saws tend to run at high RPMs and not all diamond blades are rated for high RPMs. For example, it appears that a CabKing runs at around 1500 RPM while my tile saw allegedly runs at 4400 RPM. The blade Starguy posted looks interesting. I wonder if it is usable on a high speed saw. I couldn’t find a max rpm for that blade. My CabKing runs @1725 rpm. I’m running their red sintered blade right now. It has a thinner kerf than the black blade. I think any sintered blade will have a similar service life. They’re kind of spendy but I’ve been impressed with the durability and cutting speed. When I’m hand pushing agates through a saw, I don’t baby the blade. I can’t imagine how long it would last if I did.
paulr
Member since April 2023
Post by paulr on Jun 8, 2023 19:05:59 GMT -5
I have a tile saw (8" blade) that I use to cut/trim/slab rocks. I once tried the 'BD-305 Agate Kutter' blade and determined that it wasn't really much (if any) different than a much cheaper blade. So, I have since been buying and using 'QEP Black Widow' blades for much less money. Keep in mind that tile saws tend to run at high RPMs and not all diamond blades are rated for high RPMs. For example, it appears that a CabKing runs at around 1500 RPM while my tile saw allegedly runs at 4400 RPM. The blade Starguy posted looks interesting. I wonder if it is usable on a high speed saw. I couldn’t find a max rpm for that blade. My CabKing runs @1725 rpm. I’m running their red sintered blade right now. It has a thinner kerf than the black blade. I think any sintered blade will have a similar service life. They’re kind of spendy but I’ve been impressed with the durability and cutting speed. When I’m hand pushing agates through a saw, I don’t baby the blade. I can’t imagine how long it would last if I did. FWIW, all Hi-Tech Diamond blades are designed for their saws, which run at 1725 RPM.
rockbrain
Member since January 2022
Post by rockbrain on Jun 10, 2023 9:21:18 GMT -5
I recently met a gentleman on Facebook who is part of a lapidary business in Madera, about 45 minutes from me. They cut everything with water and tile saws. He recommended THIS blade to me. I haven't used a 10" yet but purchased a 7" for my trim saw. I've not used it a lot but so far am happy with the performance. It cuts smoother with less vibration than the blade I was using. Hard to go too wrong for $25!
choochoorocks
Rock hounding
Post by choochoorocks on Jun 16, 2023 18:24:43 GMT -5
Thanks all for your recommendations. I ordered the Black Widow blade and will report back on how it cuts.
