rockbrain
Member since January 2022
Post by rockbrain on Jun 17, 2023 18:39:42 GMT -5
I've been looking at slab saws. I think I really want a 16 but options are limited. Does anyone have any experience and or opinions on the Highland Park High Tone saws?
Post by stardiamond on Jun 17, 2023 19:24:40 GMT -5
I have a 10 and a 14 (still in the box). The 10 has been reliable and slow. HP had a father's day sale for 10% off rocks and equipment. I bought slab at their zoom meeting. They even said that they would honor it for alleady placed orders when the buyer was willing to pay in full instead of having only a deposit. Worth a call or email.
Post by stardiamond on Jun 17, 2023 19:31:56 GMT -5
The 10 inch is backordered. the 12 and 14 are in stock and 10% off is being applied. From past purchases, free shipping and no sales tax.
Post by Deleted on Jun 17, 2023 19:58:10 GMT -5
If you're looking for a new 16" saw you really don't have many options to consider other than Highland Park and Covington. The HP at $3167 and the Covington at $2995.
I do not own these saws but I know people with them and I have seen them in person, that said I have very limited first hand experience with them but if I had $3k to spend on a saw right now I would go with the HP purely based on the box of the saw. Covington makes their saws out of 16g steel and HP uses 7g steel. The Covington saw shipping weight is 165lbs and the HP is 460lb.
Covingtons feel like an under-built machine and HP feel like something that has been overbuilt.
Post by stardiamond on Jun 17, 2023 20:18:59 GMT -5
I have Covington 16 combo saw. I bought it in 2008 and it sat in the box until 2014 when I retired. I paid less than half of the current price. With the clutch system it cuts very fast. The crossfeed would drift causing uneven slabs and blade binding. The clutch needs way too much adjustment. I can walk away from the HP and when I did thatwith the Covington the blade would bind and burn out the rubber belt. I was buying a lot of belts. The only objection I have to the 14 I bought is the .09 kerf. It isn't an issue with really big rocks but I cut a lot of small rough so I am glad I have the 10.
chris1956
Member since July 2022
Member is Online
Post by chris1956 on Jun 17, 2023 21:01:42 GMT -5
I too debated between Covington and HP when I bought my saws a couple years ago. I ended up getting a 10 inch trim saw and 16 inch 1100 Series saw from Covington. The clutch on the 10 inch saw gave me a lot of problems from the start. Then one day it just started working well and has been pretty much ok since then. The 10 inch saw has a few other things about the layout and design I don't like including difficulty of cleanout.
I have never touched the clutch on the 16 inch (nock on wood). I did have an issue with the 16 inch with the arbor set screw coming loose and blade stopping in the middle of a cut. Other than that, haven't had it stop in a rock. I have also had an issue with leaking of oil out around the shaft. I think it is probably a bad seal. The staff at Covington has been very helpful and they either answer the phone when you call or get back to you in a short time.
The weight difference does seem like a lot. I was thinking my 16 inch was more than 165 pounds but will have to check if I have that. My floor isn't exactly even so when I leveled the saw, I had to use some shims under legs. I did notice a little bit of flexing in the legs or box when I did this so the overall weight might be a good thing to consider. On the other hand, it is a lot easier to move 165 pounds vs 460.
Post by hummingbirdstones on Jun 17, 2023 21:14:45 GMT -5
Check out Cigar Box Rocks once in a while. They rebuilt 2 16" Nelsons that sold not that long ago.
Post by Deleted on Jun 17, 2023 21:18:23 GMT -5
Check out Cigar Box Rocks once in a while. They rebuilt 2 16" Nelsons that sold not that long ago. Currently they have a vintage 18" Lortone that they restored for $4897... I mean it looks good but that price....
Post by hummingbirdstones on Jun 17, 2023 21:31:25 GMT -5
Check out Cigar Box Rocks once in a while. They rebuilt 2 16" Nelsons that sold not that long ago. Currently they have a vintage 18" Lortone that they restored for $4897... I mean it looks good but that price.... They have used as-is equipment on there too if you're into refurbing yourself. HP's 18" slab saw is $5,097 and the Stainless Steel one is $8,795. When they restore a saw, they totally restore it, including making new parts, etc. rockbrain, you could also check with I think @azrockgeek refurbishes saws and so does Lee Rockoonz (he's in Oregon right now). A road trip to AZ to pick up a saw might be fun.
Post by jasoninsd on Jun 17, 2023 22:05:10 GMT -5
Currently they have a vintage 18" Lortone that they restored for $4897... I mean it looks good but that price.... They have used as-is equipment on there too if you're into refurbing yourself. HP's 18" slab saw is $5,097 and the Stainless Steel one is $8,795. When they restore a saw, they totally restore it, including making new parts, etc. rockbrain , you could also check with I think @azrockgeek refurbishes saws and so does Lee Rockoonz (he's in Oregon right now). A road trip to AZ to pick up a saw might be fun.
Post by Rockoonz on Jun 17, 2023 23:44:44 GMT -5
The Cigarbox Rocks rebuild saws are restored and upgraded significantly from the original 1970's technology or older, John and Sheldons copies are made in china and while their QA is far better than it was at the beginning, they are still not the same quality at all. Tony catmandewe is also a great source of good rebuilt saws and a road trip to the rock pile that is shifting the earths axis would be a bonus.
chris1956
Member is Online
Post by chris1956 on Jun 18, 2023 9:40:45 GMT -5
Covington vs HP. One thing I forgot to mention that could be very important is what it takes to align the blade on each saw. When I got my Covington 16 inch saw, the blade was not perfectly perpendicular to the arbor. Hence it was chewing up a lot more material and probably using up the blade faster. Blade alignment was not covered in the O&M manual. After calling Covington, I adjusted the blade but it is a real @$!% to do. You have to loosen a set of nuts and adjust attached set screws, one of which is behind the arbor where you have to do everything by feel because of the stuff in the way. You have to take the blade off (to get to the set screws) each time you make an adjustment and then put the blade back on to see if it worked. I finally got it close enough for what I do. But if I were cutting expensive stuff, I would be a lot more concerned about it. I found a video (link below) that shows how HP adjusts their blades. Seems a lot less difficult than the Covington saw I have. If you go with one of these two, it would be worth trying to figure out how you do the blade adjustment for each specific saw. On one of the HP videos, they make the point that Covington saws have a very small drain hole for getting oil and sludge out during cleaning. It is true on my saw but I was able to get it out without a lot of trouble (or most of it). One nice thing about the weight was that when I was draining the oil and sludge I was able to prop up the end opposite the drain to allow more out by gravity. This would be more difficult on a heavier saw. On the more expensive refurbished saws. I would think they would be a lot better but obviously, it depends on how much you are going to use the saw and what you can afford. I really love the older equipment but went with new stuff based on my circumstances. You might ask if I had it to do over again what would I do. Probably not a fair question because I now know all the little things about Covington and not other saws. By the way, speaking of O&M manuals, you will be glad to know that the manual that came with my Kingsley North cabber is the best manual that I have gotten with any piece of lapidary equipment that I have bought. Not perfect, but pretty darn good. Every time I get an O&M manual, I end up marking it up and adding to it. I often think I should offer my services to rewrite some of the terrible manuals that companies offer. My general impression is that most of the lapidary equipment manufacturers think everyone buying a piece of equipment is very experienced and knows how to do everything. Or maybe there are liability issues that they are trying to avoid. Hope this helps Chris
rockbrain
Post by rockbrain on Jun 18, 2023 15:01:23 GMT -5
Thanks for all the inputs. A lot of good info here. I did look at CigarBox and I watched all the HP videos. Still can't find one that shows how you engage and disengage the power feed. I think a 14 probably makes the most sense for me as I have a 24 and I'm looking for something to cut smaller rough. I don't think I care much for the vice in the HP HighTone but the upgrade vertical vice is only $213. Maybe something will pop up on Craigs list. I'm not in a tremendous rush.
Post by stardiamond on Jun 18, 2023 15:32:40 GMT -5
I bought the 14 (still in box) and thought it came with a vertical vise like the 10. On the 10 the clutch handle is a lever to the right of the carriage and the clutch is a spring attached to a curved threaded piece of metal that sits on the feed rod. My spring broke I waited more than a month for the spring to arrive. I am not particularly handy and when I replaced the spring there wasn't enough tension so the carriage wouldn't advance. I put a threaded metal clip from my Covington behind the clutch assembly and the feed works.
rockbrain
Post by rockbrain on Jun 20, 2023 16:51:00 GMT -5
I think I'm going to have to go with the HP 16. Everything about it looks superior to the HighTone 14. It's a much heavier box, 7 gauge vs 16 gauge. It comes on a stand. I think the feed system carriage and everything is made better. If I got the HighTone I would get the vice upgrade but the vice still isn't as nice. I thought the 16 would be a lot bigger but it's not. 4" longer and the box is actually 1/2" narrower. It would be heavy to move but comes with casters. It's got a better blade which isn't a huge deal. the 16 also has a 3 speed adjustable drive. 460 lbs for the 16 vs 145 for the 14 but I don't imagine I'll be carrying it much and the 16 comes with casters. I guess I'll have to wait again as the 16 is out of stock but the container is on it's way.
Post by stardiamond on Jun 20, 2023 18:02:55 GMT -5
Did you get the discount?
rockbrain
Post by rockbrain on Jun 20, 2023 18:49:51 GMT -5
I didn't hear anything about a discount. She did throw the oil in for free. The only discount mentioned was 7% for a referral.
Post by stardiamond on Jun 20, 2023 19:01:08 GMT -5
It expired. I posted it on this topic on the 17th and it expired on the 18th,
Post by Starguy on Jun 20, 2023 19:15:38 GMT -5
I have a 16” Covington. It has performed well but it is a hobbyist saw. I wish I would have spent the extra money to get an 18” or bigger. They are much heavier duty.
Post by Rockoonz on Jun 20, 2023 22:33:51 GMT -5
16 is a good size, and the HP clone will no doubt be better than the Lortone clone, and a 14" blade will fit it with just a bit more oil for less kerf when desired. I have the 16" original US made M3 close to being on deck for a rebuild, maybe be done early next year if I can repair or replace the original lexan acrylic lid. When you get it you should immediately get the pillow block arbor bearing dimensions and part number, and find an original Sealmaster or SKF replacement for when the chinese ones die, if you run it hard like you should they will go a year at best.
