canuckienns
Member since March 2022
Post by canuckienns on Jul 2, 2023 13:26:25 GMT -5
I was just finishing up the touches on a nice old Frantom cabbing machine with a slab saw on one end. When I dropped the saw table onto the tank with the new 10 inch blade thinline installed, the blade in binding and tight on one side. I could , but I would rather not file out the slot for the blade for clearance. How are spindles installed. Was it a press fit or threaded oe? ?. Thanking you for your help
Post by Peruano on Jul 2, 2023 14:31:53 GMT -5
Unless you can see an obvious shoulder that will prevent the shaft from moving in the correct direction, I'd suspect you can move it as needed with a press or hammer blows (cushioned with a block of wood). I had to adjust an arbor for an HP trim saw for the same reason.
canuckienns
Post by canuckienns on Jul 3, 2023 6:59:15 GMT -5
I cant see a shoulder, so it must be a press fit. There is a little space between the spindle and the shaft. Thanks
