sugarskull7
Member since September 2023
Post by sugarskull7 on Sept 21, 2023 14:47:34 GMT -5
Hi all! I’m a SoCal rock hound and have finally gotten my tumbler up and running after a few years. I have a piece of known, unpolished Big Sur jade I’m about to tumble, but noticed one of the rocks from a previous batch might be jade as well. Under a loupe it looks fibrous. It’s very hard, took a long time to polish. In the pic (if I can manage to upload it this time) the known piece is the top stone, the mystery piece is the polished one beneath it. Thoughts?
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Sept 21, 2023 20:25:28 GMT -5
They look like the same material to me!
Post by RWA3006 on Sept 21, 2023 22:20:50 GMT -5
Might need to do a specific gravity test to find out. It needs to be around 3.3 specific gravity. Looks similar in the photo except for the luster. I notice the bottom stone appears to shine more than the top which makes me wonder. Jade usually has a waxy luster like the top stone.
sugarskull7
Post by sugarskull7 on Sept 22, 2023 9:41:26 GMT -5
The bottom stone is tumble polished, the top one is not, that’s why the luster is different.
Post by Mel on Sept 27, 2023 14:27:01 GMT -5
Looks like jade to me; you can rub it against a porcelain tile and if it leaves a colorless streak, it's jade. If it leaves any color, it's probably serpentine. Can also try rubbing the 2 pieces together. If it's serpentine you'll get kind of a white streak, which you won't get with jadeite/nephrite.
