orneryboi
Member since November 2022
Post by orneryboi on Nov 29, 2023 19:00:15 GMT -5
Found near Challis ID, incredible under/over plumage but I'm skeptical as to how well it would cab due to horizontal fractures.. Thanks for looking!
chris1956
Member since July 2022
Post by chris1956 on Nov 29, 2023 19:45:35 GMT -5
Cool looking stuff!
Post by Pat on Nov 29, 2023 20:09:38 GMT -5
Those aren’t really teeth I see. What are they? Interesting. Thanks.
Post by jasoninsd on Nov 29, 2023 20:16:19 GMT -5
This stuff looks like a cross between Missouri Lace and Silver Lace Onyx! Really cool!!
Post by Pat on Nov 29, 2023 20:21:33 GMT -5
This stuff looks like a cross between Missouri Lace and Silver Lace Onyx! Really cool!! Or maybe Dentists’ Delight…… …
Post by jasoninsd on Nov 29, 2023 20:26:01 GMT -5
dillonf
Hounding and tumbling
Member since February 2022
Post by dillonf on Nov 29, 2023 20:26:08 GMT -5
Really cool stuff! Thanks for sharing!
dillonf
Post by dillonf on Nov 29, 2023 20:26:44 GMT -5
Post by liveoak on Nov 30, 2023 7:42:49 GMT -5
Pretty funky looking stuff. I'm wondering, if you have another piece, if you slabbed it the opposite way would it be more stable ?
Patty
Post by realrockhound on Nov 30, 2023 11:31:56 GMT -5
It’s a seam agate. So it more than likely pushed up from under the ground somewhere. Which means there is more than likely more
pebblesky
Member since September 2022
Member is Online
Post by pebblesky on Nov 30, 2023 12:34:39 GMT -5
Very cool! These slabs almost Look like those wolf-teeth pendant worn by tribe people.
Post by velodromed on Nov 30, 2023 15:10:44 GMT -5
Crazy cool stuff I’d not seen before! Thanks for posting it.
Mark K
Member since April 2012
Post by Mark K on Nov 30, 2023 15:37:42 GMT -5
I have never seen anything even close to that around Challis.
rockbrain
Member since January 2022
Post by rockbrain on Nov 30, 2023 15:38:16 GMT -5
Found near Challis ID, incredible under/over plumage but I'm skeptical as to how well it would cab due to horizontal fractures.. Thanks for looking! There's always the option of stabilization.
orneryboi
Post by orneryboi on Dec 12, 2023 18:59:51 GMT -5
Thanks all! This was a surprise I found while looking for blue agate nodules, it had a tiiny window so I was fortunate to notice it in the first place. Can't wait to get back up there... so much more terrain to cover. Pat- they're just slabs of plume agate, pretty gnarly for sure.. Patty- I tried cabbing a small end-piece but it's just fractured all around.. was gonna post a picture of it but I can't photograph very well:) Realrockhound- good call, can't wait to get back there and find the lode. We stopped at the first hill we came to, and they ran as far as the eye could see.. Mark K- same- I'd heard of Challis plume agate but this is very different. Rockbrain- I recently jumped down the rabbit hole (warren) on stabilizing, hopefully I can find a technique that works.. Fingers crossed!
Mark K
Post by Mark K on Dec 12, 2023 19:25:41 GMT -5
Have you been to the fluorite spot that they reclaimed with extreme prejudice?
Post by realrockhound on Dec 12, 2023 19:28:11 GMT -5
Have you been to the fluorite spot that they reclaimed with extreme prejudice? Extreme prejudice? Tell me more 😂
Mark K
Post by Mark K on Dec 12, 2023 22:19:34 GMT -5
There was a spot that had a fluorite mine and the forest service came in and destroyed everything claiming it was for safety. Then they covered a deposit that was not unsafe at all with riprap and then dumped tons of dirt over it so no one could work the safe deposit. They did it just to be assholes. The mine was like a fairy land with the huge veins of material going off into the walls and would light up like magic when you put a really strong light to it.
Mark K
Post by Mark K on Dec 12, 2023 22:26:48 GMT -5
Post by realrockhound on Dec 12, 2023 22:28:00 GMT -5
There was a spot that had a fluorite mine and the forest service came in and destroyed everything claiming it was for safety. Then they covered a deposit that was not unsafe at all with riprap and then dumped tons of dirt over it so no one could work the safe deposit. They did it just to be assholes. The mine was like a fairy land with the huge veins of material going off into the walls and would light up like magic when you put a really strong light to it. That does not surprise me one bit. Now you got me pissed off with the pine pigs more than usual.
