jeg
Member since January 2024
Post by jeg on Jan 25, 2024 7:51:17 GMT -5
when running batch 2,3 or more weeks how often should you can to new grit thanks
rocknewb101
Member since October 2022
Post by rocknewb101 on Jan 25, 2024 9:08:21 GMT -5
I typically run all of my stage one through rotary tumblers and then stage 2-4 is done in the mini sonic. For stage one, I change out every week. So Sunday is clean out day, I'll pull out the rocks, give them a good rinse, hold any ready for stage 2, and then put the rest back in the barrel, add more rough if needed to make the barrel 2/3 full, and then add new grit. Some weeks I could probably let it go 10 days because i have a little left over grit, but to keep it so clean out is on the weekend I usually just go Sunday-Sunday. I do this as many times as needed until the rocks are ready for stage 2. Many of my stage one rocks stay in stage one for months until they are where I want them, but I clean out weekly. Hope this helps!!
Post by victor1941 on Jan 25, 2024 10:39:45 GMT -5
Jeg, I run a UV-18 vibe and my stones or unpolished cabs are 99% preshaped on the flat lap or grinder wheel before they are run through the stages. I use 2 or 3 days for each stage and then clean thoroughly before moving to the next step. Step one 100/220 might be run twice to make sure all deep scratches are removed before going to the next step. I am retired so cleanout is determined after visually checking dry material under the loupe before moving on- I take samples. Please remember that my rough is a different in starting shape.
rocknewb101
Post by rocknewb101 on Jan 25, 2024 11:10:12 GMT -5
Jeg, I run a UV-18 vibe and my stones or unpolished cabs are 99% preshaped on the flat lap or grinder wheel before they are run through the stages. I use 2 or 3 days for each stage and then clean thoroughly before moving to the next step. Step one 100/220 might be run twice to make sure all deep scratches are removed before going to the next step. I am retired so cleanout is determined after visually checking dry material under the loupe before moving on- I take samples. Please remember that my rough is a different in starting shape. Victor - do you do 120/220 for stage one because you are using a vibe? So your flat lap work would be considered the 60/90 stage? Just curious. I've often wondered about shaping cabs and putting them in the mini to polish, but haven't tried that yet.
wseaton
Post by wseaton on Jan 29, 2024 13:54:53 GMT -5
You change grit when it's consumed / broken down. This also varies according to how your barrel is loaded. This also assumes were talking about stage 1-3. Final polish has it's own rules. Stage 1 is also more variable dependant based on other conditions.
There's endless discussion on this topic, but a lot of opinions on the are just plain false.
My 3lb barrels go through two heaping tablespoons of 120-500 in about 3 days max. A far cry from a lot of people saying you need to tumble for weeks. My seemingly short times are due to using more media in the barrels and fewer rocks to polish. You can prove this yourself with large ceramic or 3/4" river gravel. Both of which make exellent filler media. Fill your barrel 2/3 full with either, and two tablesppons of 120/220, and check it every day to see how long it takes for the grit to totally be convertd to grey goo with no grit left. Will take about 72 hours.
Take that same barrel and fill it 3/4 full of 1.5 " rocks and your times will increase dramatically. Much less surface area to grind against and less fluid tumbling rotation. So, it all depends on how you fill your barrel.
I can final polish a 3" rock in 3 days if I use 1/4 ceramic and nothing else. Again, if that barrel was full of 1.5" rocks the times go up a factor of at least 3-4X. Just physics.
jeg
Post by jeg on Jan 30, 2024 8:34:27 GMT -5
thank for all the information
