realrockhound
Member since June 2020
Member is Online
Post by realrockhound on Mar 24, 2024 21:51:28 GMT -5
khara
Member since September 2022
Post by khara on Mar 25, 2024 7:10:46 GMT -5
Nice. It’d (it’ll) be interesting to see how that cabs up.🤓
rocknewb101
Member since October 2022
Post by rocknewb101 on Mar 25, 2024 9:39:40 GMT -5
Nice! You don't normally see that in jasper do you? Or do you? I agree - interested to see what you do with it.
Post by 1dave on Mar 25, 2024 9:56:07 GMT -5
You never know the best way to cut! Have to just take a chance. Luck of the Irish/Viking/Whoever
realrockhound
Member is Online
Post by realrockhound on Mar 25, 2024 10:14:26 GMT -5
Nice! You don't normally see that in jasper do you? Or do you? I agree - interested to see what you do with it. It is. Just not as common to this degree with batcave. This material generally forms in 1/4”-1/2” layers. So cutting vertically, isn’t typically the best way to cut it due to lack of material. This one had a thick layer so gave it a shot. Should produce some nice half batcave have moss agate cabs
Post by MsAli on Mar 25, 2024 10:19:54 GMT -5
My understanding is that is more rim jasper than bat cave ?
rocknewb101
Post by rocknewb101 on Mar 25, 2024 10:21:41 GMT -5
Nice! You don't normally see that in jasper do you? Or do you? I agree - interested to see what you do with it. It is. Just not as common to this degree with batcave. This material generally forms in 1/4”-1/2” layers. So cutting vertically, isn’t typically the best way to cut it due to lack of material. This one had a thick layer so gave it a shot. Should produce some nice half batcave have moss agate cabs Oh...nice! I will look forward to seeing final product! I love it when the cutting turns out right!
realrockhound
Member is Online
Post by realrockhound on Mar 25, 2024 10:46:15 GMT -5
My understanding is that is more rim jasper than bat cave ? It’s 100% batcave. It just has a moss jaspagate layer under the porcelain jasper. The stuff they refer to as rim jasper, tends to be more of a mix of green, reds, yellows etc, and contains little to none of the brown/tan bat cave. That stuff also forms in bigger seams. I think I got some nice pieces of that I can post later.
Post by MsAli on Mar 25, 2024 11:12:48 GMT -5
That would be cool to see
We have several unprocessed Bat Cave and I don't think any of it has those colors in it
realrockhound
Member is Online
Post by realrockhound on Mar 25, 2024 11:25:41 GMT -5
That would be cool to see We have several unprocessed Bat Cave and I don't think any of it has those colors in it generally from all that I’ve seen (and I got probably 800lbs+ of it) it’s just thin layers that don’t have the moss. And what does is generally very little. I’ll send you some of the rim jasper if you’d like to work some. I just need to remember where I put it 😂. I know I have some buckets laying around somewhere.
Post by MsAli on Mar 25, 2024 14:38:48 GMT -5
That's like me, I don't know where half the stuff is 😅
realrockhound
Member is Online
Post by realrockhound on Mar 25, 2024 14:49:39 GMT -5
That's like me, I don't know where half the stuff is 😅 I got stuff I still need to send out to others on the list. If you don’t hear from me by this weekend, remind me. I’ll go look for it and I’ll try to slab some up and send some out. No charge
Post by MsAli on Mar 25, 2024 20:02:57 GMT -5
Appreciate it very much
realrockhound
Member is Online
Post by realrockhound on Mar 26, 2024 19:48:51 GMT -5
Now THIS is 100% bonafide rim jasper. Mined by me. Is it alright if I send you some slabs of this crap?
realrockhound
Member is Online
Post by realrockhound on Mar 26, 2024 20:15:57 GMT -5
Thanks for dropping by, but you don't need to see what I do when I get sick and tired of me. Cut some rocks for awhile since you're already here. But don't expect a smile and look out for all the tears. You 'bout to get yourself a lesson in depression. From the king of his profession
Post by 1dave on Mar 26, 2024 21:00:23 GMT -5
Beautiful Stuff. Too bad I don't saw or cab anymore. If I did, I'd take all you would give.
realrockhound
Member is Online
Post by realrockhound on Mar 26, 2024 21:05:08 GMT -5
Beautiful Stuff. Too bad I don't saw or cab anymore. If I did, I'd take all you would give. this is what I consider the good stuff. Lots of drab crap out there that’s not even remotely close to this. When you get the moss, you know it’s good
Post by jasoninsd on Mar 26, 2024 22:46:31 GMT -5
realrockhound - Charley Crocket would say that's slightly better than "crap"!
realrockhound
Member is Online
Post by realrockhound on Mar 26, 2024 22:54:55 GMT -5
realrockhound - Charley Crocket would say that's slightly better than "crap"! I’m going to go see him in June actually. Lesson in depression is my theme song 😂
Post by jasoninsd on Mar 26, 2024 23:02:39 GMT -5
