petoskeycheryl
Can't wait for spring in Michigan.
Member since November 2019
Post by petoskeycheryl on Mar 26, 2024 13:36:26 GMT -5
I would like to cut some shapes from my Petoskey stone slabs. What kind of blade and saw would I need for this? A ring saw?
realrockhound
Member since June 2020
Member is Online
Post by realrockhound on Mar 26, 2024 14:04:43 GMT -5
Band saw, jig saw. Water fed. Diamond blade
chris1956
Member since July 2022
Member is Online
Post by chris1956 on Mar 26, 2024 15:29:08 GMT -5
You might want to look through this recent thread forum.rocktumblinghobby.com/thread/104857/lapidary-diamond-band. That said, I have cut Petoskey stone slabs on a 10-inch diamond blade trim saw. realrockhound mentioned water fed. That is probably better than oil for Petoskey stones. I have always used oil because it seems to work better for harder material and I haven't gone to the effort of changing to water for softer stones. Petoskey stones can be a lot more porus than other rock materials and you may get a lot of oil soaking into the slab you are cutting. This hasn't been an issue for me but you should know that the oil will change the appearance of the stone (will tend to make it darker and look more like it does wet which is good from an appearance standpoint). However, as the oil evaporates, the slab or shape may return to the "not dry" look. If you have a high quality Petoskey stone, the finished polished look (assuming you are going to polish the shapes) will look good regardless. There are also ways to make the oil (wet) "look" be more or less permanent for Petoskey stones. Submerging the stone in food grade mineral oil (from grocery or hardware store) and baking at 200F for 2 hours will give you that "wet" look for a long time. I have been doing this on some lower quality Petoskey stones for more than 2 years and the wet look doesn't seem to go away. I haven't sold any treated stones so haven't been concerned about "altering" the appearance this way. Also, the oil baking method won't do much for a really low quality Petoskey stone.
realrockhound
Member is Online
Post by realrockhound on Mar 26, 2024 15:33:29 GMT -5
If oil. Put your slabs etc, in kitty litter for a few days. Sucks the cat caca right outta them
