mirkee
Started tumbling a couple of months ago but now have four tumblers. Very interested in the hobby.
Member since March 2024
Post by mirkee on Apr 27, 2024 17:13:52 GMT -5
I have been sorting out getting a trim saw for a while. I overthink most of this stuff, unfortunately.
I'm more of a tumbler. I create sort of cabs that could be used in a pendant with a more organic look, which i prefer. Frankly, the regimented look of traditional cabs leave me cold. I pick up most of my rocks at local beaches here in CA.
My main use of a saw would be to trim jagged pieces of rocks that work themselves to the beach via creeks. Very jagged stuff, mostly jasper-like. I also find smaller pieces, less than tennis ball size of rhyolite type of stuff which is fairly round and smooth. Those rounder pieces I would like to essentially slab.
Wondering if the 6" Hi-Tech plastic trim saw would work for my needs, especially to trim jagged rocks prior to tumbling.
Thank you all.
orneryboi
Member since November 2022
Post by orneryboi on Apr 27, 2024 19:36:01 GMT -5
It sounds like you know what you need:) With a 6 inch blade you'll only be able to slice rocks up to about 2 inches in diameter (my only concern tbh). Down the road, will you want to slice/trim larger chunks? If you're mostly trimming jasper edges and you'll possibly need more blade one day, save money and get a larger wet tile saw. The Hi-Tech will be more precise/acute and if that's what you need, then, you already know:) Let us know what you end up getting.
ThomasT
Member since June 2022
Post by ThomasT on Apr 27, 2024 20:55:47 GMT -5
An inexpensive wet tile saw will trim up small stuff at a low cost.
