gemfeller
Member since June 2011
Post by gemfeller on May 2, 2024 12:22:44 GMT -5
I love rutilated quartz and I invested in a fairly large parcel of rough many years ago. But it's challenging rough: odd shapes, pits, and other issues that make selecting and orienting cabs unusually difficult. And none I've cut so far was more difficult than this one.
I could tell from the rough there was unusual beauty to be revealed if only I could navigate all the problems. The main ones were the shape of the rough, and deep pitting that was directly above the most attractive parts -- as usual! And orienting the brightest area to the top of the hoped-for stone was almost impossible because of the shape. I must have cut 4 or so "bottoms" at different angles to get the best orientation possible. After I got it as close as I could, it was breath-holding time as I carefully tried to eliminate the seemingly bottomless pits on the top.
After an hour or so of "cut a little, look a lot," success! The end result weighs 17.57 carats and measures 25 x 14.5 x 8 mm. The video only hints at the stone's brightness. In hand it is almost blinding as it turns in he light. Thanks for looking!
roQhound
Member since March 2023
Post by roQhound on May 2, 2024 12:35:52 GMT -5
That's a beauty and I can see that it would be really difficult to work with that material. Great job!
pebblesky
Member since September 2022
Post by pebblesky on May 2, 2024 12:58:21 GMT -5
The end result is super satisfying and totally worth your effort!
gemfeller
Post by gemfeller on May 2, 2024 13:29:36 GMT -5
The end result is super satisfying and totally worth your effort! Thanks -- wish you could see it in hand.
gemfeller
Post by gemfeller on May 2, 2024 13:31:43 GMT -5
That's a beauty and I can see that it would be really difficult to work with that material. Great job! Thanks. It's normally pretty easy to cut, but this particular stone was a hot mess in the rough. I feel lucky to have salvaged a cab out of it much less a really nice one.
realrockhound
Member since June 2020
Member is Online
Post by realrockhound on May 2, 2024 13:37:23 GMT -5
At work now, but hopefully I’ll be on lunch soon. Can’t wait to check out the vid. Still a type of material I need to get around to cutting
Post by rockjunquie on May 2, 2024 14:03:08 GMT -5
Mic drop!!
gemfeller
Post by gemfeller on May 2, 2024 14:11:40 GMT -5
I guess I like your comment but I have no idea what it means
khara
Post by khara on May 2, 2024 14:18:02 GMT -5
Wow, that’s gorgeous.👍
Post by rockjunquie on May 2, 2024 14:53:10 GMT -5
I guess I like your comment but I have no idea what it means It means you just dropped something so fabulous no one can top it.
gemfeller
Post by gemfeller on May 2, 2024 18:25:34 GMT -5
I guess I like your comment but I have no idea what it means It means you just dropped something so fabulous no one can top it. Now I REALLY like it!
chris1956
Member since July 2022
Member is Online
Post by chris1956 on May 2, 2024 18:51:49 GMT -5
That is outstanding!
Post by jasoninsd on May 2, 2024 21:16:24 GMT -5
OMG! That is the way this material is supposed to look when worked! Outstanding!! Oddly...I just finished working a cab of rutilated quartz as well...but I still need to polish the back. It looks NOTHING like yours!
Post by liveoak on May 3, 2024 6:11:55 GMT -5
Looks WELL worth your efforts ! A super nice one.
Patty
gemfeller
Post by gemfeller on May 3, 2024 14:21:00 GMT -5
OMG! That is the way this material is supposed to look when worked! Outstanding!! Oddly...I just finished working a cab of rutilated quartz as well...but I still need to polish the back. It looks NOTHING like yours! This one's unusually nice, so don't be disappointed with yours. I could see the potential in the rough but I had almost nothing to work with in the way of material. I still haven't given it a final polish because I'm pondering having another go at it to change the angle of the bottom to create a near cat's-eye effect. But it's a gamble and I'd lose a fair amount of weight as well as narrowing the shape quite a bit. Decisions, decisions....
Post by rockjunquie on May 3, 2024 14:49:37 GMT -5
OMG! That is the way this material is supposed to look when worked! Outstanding!! Oddly...I just finished working a cab of rutilated quartz as well...but I still need to polish the back. It looks NOTHING like yours! This one's unusually nice, so don't be disappointed with yours. I could see the potential in the rough but I had almost nothing to work with in the way of material. I still haven't given it a final polish because I'm pondering having another go at it to change the angle of the bottom to create a near cat's-eye effect. But it's a gamble and I'd lose a fair amount of weight as well as narrowing the shape quite a bit. Decisions, decisions.... It's gorgeous the way it is.
gemfeller
Post by gemfeller on May 3, 2024 15:06:03 GMT -5
This one's unusually nice, so don't be disappointed with yours. I could see the potential in the rough but I had almost nothing to work with in the way of material. I still haven't given it a final polish because I'm pondering having another go at it to change the angle of the bottom to create a near cat's-eye effect. But it's a gamble and I'd lose a fair amount of weight as well as narrowing the shape quite a bit. Decisions, decisions.... It's gorgeous the way it is. Thanks. I'm coming to that conclusion myself. I don't think my poor heart could stand the tension of a rec-cut anyhow.
pebblesky
Post by pebblesky on May 3, 2024 15:06:54 GMT -5
