tribeunited
Not all materials look exactly the same. But all exact materials are exactly the same.
Member since May 2024
Post by tribeunited on May 27, 2024 17:46:37 GMT -5
Post by vegasjames on May 27, 2024 17:58:38 GMT -5
First one looks like it could be serpentine.
Second looks lke copper ore. Copper minerals often look a lot alike and can be hard to ID without knowing original location they are from.
tribeunited
Post by tribeunited on May 27, 2024 18:06:39 GMT -5
Thanks! I also thought serpentine, but wasn't sure because dry its black like obsidian. It only has that pretty pattern and color when its wet.
Post by vegasjames on May 27, 2024 18:21:48 GMT -5
Thanks! I also thought serpentine, but wasn't sure because dry its black like obsidian. It only has that pretty pattern and color when its wet. Serpentine comes in a variety of colors including black, white, purple, brown, yellow and green.
tribeunited
Post by tribeunited on May 27, 2024 18:24:42 GMT -5
OOH! Thanks so much!
Post by jasoninsd on May 27, 2024 18:32:45 GMT -5
This is dangerous...I'm totally going against James's IDs! LOL
That first one looks like Velvet Sheen Obsidian to me. I've worked some under the name of Royal Velvet. I have some threads on here somewhere...
tribeunited
Post by tribeunited on May 27, 2024 18:36:50 GMT -5
I'll look for those threads. I'm happy to get all answers, at the very least it points me in a direction instead of spinning in circles. I can't say thank you enough
Post by rmf on May 27, 2024 18:40:03 GMT -5
check the hardness serpentine is soft scratch with a pocket knife, obsidian should have the same hardness more or less than glass. my first glance says vegasjames is correct but the hardness will tell
Post by vegasjames on May 27, 2024 18:42:38 GMT -5
This is dangerous...I'm totally going against James's IDs! LOL That first one looks like Velvet Sheen Obsidian to me. I've worked some under the name of Royal Velvet. I have some threads on here somewhere... If obsidian, the chips on the edge wold have chonchoidal fractures. Hard to tell for sure from the pic, but the edge chips I can see do not look conchoidal. Maybe pics, dry and from different angles can help.
Post by jasoninsd on May 27, 2024 18:43:17 GMT -5
This is dangerous...I'm totally going against James's IDs! LOL That first one looks like Velvet Sheen Obsidian to me. I've worked some under the name of Royal Velvet. I have some threads on here somewhere... If obsidian, the chips on the edge wold have chonchoidal fractures. Hard to tell for sure from the pic, but the edge chips I can see do not look conchoidal. Maybe pics, dry and from different angles can help. Good point!!
tribeunited
Post by tribeunited on May 27, 2024 18:45:35 GMT -5
It's a soft scratch. Serpantine! Thanks so much
