mirkee
Started tumbling a couple of months ago but now have four tumblers. Very interested in the hobby.
Member since March 2024
Post by mirkee on Jun 4, 2024 19:56:14 GMT -5
I only have a 6" trim saw. Instructions say that water alone is OK but water with some additive (cooling) is even better. Which additive do you all recommend. I want something concentrated which can be diluted for use as I don't want to have gallons of the stuff around. No room. Thanks in advance.
Post by Rockoonz on Jun 4, 2024 20:10:39 GMT -5
I am on an additive search as well, or more accurately a new additive. I don't know if it's the hard more alkaline water here, or a change in the additive, but the Johnson Bros additive I have used for years now froths.
Post by opalpyrexia on Jun 4, 2024 23:50:05 GMT -5
I use Finish Jet-Dry. It'surfactant action decreases water tension, which enables increased contact between water and other surfaces. That closer contact enhances heat transfer. It’s readily available and it takes just a couple of drops in a water-based trim saw.
Post by Rockoonz on Jun 5, 2024 2:15:27 GMT -5
I've heard of using wetting agents, imagine just straight borax might do it. In my case I don't want to drain the saw, so rust inhibitors are also important. After this years trip north I want to finish the trim saw with the dry sump and water pump so the blade won't be submerged when not cutting.
markymark
Member since November 2015
Member is Online
Post by markymark on Jun 5, 2024 16:46:39 GMT -5
Diamond pacific has a product called Water Aid, says 6 drops per pint, prob just another form of jet dry.
Post by tims on Jun 11, 2024 18:04:30 GMT -5
I use Tool Cool water-soluble synthetic lube / coolant from the Rock Shed. $8 / 8 oz ain't cheap but i don't cut very much and it seems to work ok. No rust issues on my blade ever (pan is cast aluminum). Plus i like having an excuse to cruise over to Keystone a couple times each summer.
EDIT: Oh yeah, mix is 10:1 for cutting so 8oz doesn't go very far.
