demihuman
Member since May 2024
Post by demihuman on Jun 17, 2024 20:54:34 GMT -5
Post by chris1956 on Jun 17, 2024 21:23:06 GMT -5
Did it fall apart when you cut the rocks? If so here is a link to a somewhat simple method of stabilizing soft material. I don't know how it would work on the cracked material it looks like you have.
demihuman
Post by demihuman on Jun 17, 2024 22:22:55 GMT -5
Oh that’s cool! Some of it crumbled when I cut it. I am thinking that I need to hold out for better rocks to bring home.
Post by rockjunquie on Jun 18, 2024 6:56:45 GMT -5
Looks like something vegasjames might pick up. I don't think it's brecciated jasper. Maybe James will know.
tribeunited
Not all materials look exactly the same. But all exact materials are exactly the same.
Member is Online
Post by tribeunited on Jun 19, 2024 16:27:22 GMT -5
I'm replying to this so his thread moves up to the top. I posted too many yesterday and buried this request, he still needs an ID. Sorry demihuman!
khara
Member since September 2022
Post by khara on Jun 19, 2024 16:43:01 GMT -5
I don’t know the ID but I also wouldn’t call it brecciated. As for cabbing it, when I have a piece like this that is obviously filled with fractures and I want to avoid wasting my time, I’ll actually intentionally drop the slab from a foot or so at least above a hard table or the garage floor. This way it’ll fracture where it’s going to and I can attempt a cab in the pieces that are left. I don’t know if this method ends up adding fractures that maybe weren’t already there. But I figure if it’s weak it’s better to find out early on.
Post by vegasjames on Jun 19, 2024 18:21:17 GMT -5
Looks like something vegasjames might pick up. I don't think it's brecciated jasper. Maybe James will know. From the rounding of the clasts, I would say it is a conglomerate instead of a breccia.
From the crystal structure on the outside, I doubt it is a jasper either. With the cubic structure and base color, I would say it is very likely dolomite (calcium magnesium carbonate), which is very common at a lot of our mines around here. Sometimes it is stained by other minerals such as iron making it red, brown or yellow, or by copper giving it a green or blue color.
The brown in stone is limonite, which is a general term for a mix of iron oxides and hydroxides, and not an actual mineral. It is also very common at a lot of mines and frequently found with both dolomite and copper minerals.
