andyiii
Member since May 2024
Post by andyiii on Jun 18, 2024 11:24:51 GMT -5
Hey folks,
I've just started my first stage 1 run in a Rebel 17 tumbler and have a few questions that I have not found answers to yet:
1) this is a 17 lb. barrel and it rotates at exactly 20 rpm. Is that too slow? I feel like I've seen folks talking about tumbling at 40 rpm. I realize that slower = gentler, but it has to be fast enough to be effective; need that happy medium.
2) I used 16 tablespoons of 60/90 SiC to get things going. I just learned that 16 tablespoons = 1 cup. That seemed like an excessive amount of grit as I poured it in. With larger barrels do you still use roughly 1 tbsp per pound of rock?
3) Just as with the 3 lb. barrels, I used only rocks (various sizes) for stage 1, no media. Is this correct or do I need cushioning media since the rocks are falling further as they turn?
4) Since this barrel is so much bigger and the rocks are also, should I consider starting with a grit coarser than 60/90 SiC?
Thanks, Andy III
Post by pebblesky on Jun 18, 2024 11:37:21 GMT -5
1. I remembered seeing discussion about low-speed Rebel 17 here. 20 rpm should do fine. 2. I think I use a bit over one cup. Seems to work fine. No noticeable unused grit left after a week of tumbling. 3. I don't use media for Rebel 17 either. I use small agate fillers, which is more for carrying the grits around and grinding effectively, than serving as cushioning.
saaz
Member since October 2023
Post by saaz on Jun 18, 2024 20:14:46 GMT -5
Can't comment on 1. 2. I use 3/4 cup in a 12lb Lortone, so that seems about right. My grit seems to be all used up at the end of a week. 3. For stage 1 in the 12lb I use only rocks (unless I have new ceramic that I want to smooth off). I also try to add some small rocks as filler. 4. I wouldn't worry about it. I recently posted about an experiment where I found 120/220 was equally as effective as 60/90 in my 12lb, if measured by weight. Someone else tested a 3lb and found 120 was *more* effective iirc. That all started with an old article that found 80 to 220 was the ideal range.
andyiii
Post by andyiii on Jun 19, 2024 0:17:42 GMT -5
Great info! Thanks, all!
