Post by cobbledstones on Jun 19, 2024 20:46:42 GMT -5
here is something weird, diamond milling bits for a CNC machines. I use them in my drill press to make tiny grinding wheels for tight inside curves. These are 80 grit with tons and tons of life on them $5 each. Edited to add: shaft is 1/2" diameter, Cutting head is 3/4" diameter and shafts are 5" long, and the cutting surface is 1" wide along the shaft. I also found some 220 grit in the box. ![](https://hosting.photobucket.com/images/f157/simpsons_guest/20240619_094121.jpg)
Post by rockjunquie on Jun 19, 2024 20:48:18 GMT -5
here is something weird, diamond milling bits for a CNC machines. I use them in my drill press to make tiny grinding wheels for tight inside curves. These are 80 grit with tons and tons of life on them $5 each. ![](https://hosting.photobucket.com/images/f157/simpsons_guest/20240619_094121.jpg) shipping cost? Just asking.
Post by cobbledstones on Jun 19, 2024 23:19:12 GMT -5
here is something weird, diamond milling bits for a CNC machines. I use them in my drill press to make tiny grinding wheels for tight inside curves. These are 80 grit with tons and tons of life on them $5 each. ![](https://hosting.photobucket.com/images/f157/simpsons_guest/20240619_094121.jpg) shipping cost? Just asking. I think I can fit at least 5 in a small flat rate box ($10.40). I will get a box tomorrow and see exactly how many I can stuff in one of those boxes.
agatewhisperer
Member since May 2020
Post by agatewhisperer on Jun 20, 2024 9:33:34 GMT -5
Post by cobbledstones on Jun 20, 2024 17:27:53 GMT -5
they look sintered to me. I have used 1 for over 3 years now and it still cuts good. This is the best pic I can get of the 220 and 80 grits. What do you think? ![](https://hosting.photobucket.com/images/f157/simpsons_guest/20240620_152324.jpg) ![](https://hosting.photobucket.com/images/f157/simpsons_guest/20240620_154119.jpg)
Post by cobbledstones on Jun 20, 2024 17:29:50 GMT -5
shipping cost? Just asking. I think I can fit at least 5 in a small flat rate box ($10.40). I will get a box tomorrow and see exactly how many I can stuff in one of those boxes. Got the box and put some in. I can fit 20 without packing material.
markymark
Member since November 2015
Post by markymark on Jun 21, 2024 0:01:26 GMT -5
What do they measure
Post by cobbledstones on Jun 21, 2024 0:43:52 GMT -5
