Post by cobbledstones on Jun 20, 2024 23:34:34 GMT -5
Going to start a new little project and just ordered the parts. I am going to try and make a little hard wheel set out of these cnc milling bits. I just ordered some supplies Going to source the rest with scraps lying around the shop
Post by 1dave on Jun 21, 2024 10:29:52 GMT -5
Nice start.
aGates
Building a silver studio
Member since January 2021
Post by aGates on Jun 21, 2024 11:22:32 GMT -5
Neat idea what's your plan with it.
Post by cobbledstones on Jun 21, 2024 22:30:48 GMT -5
aGates, I am going to use the coupler to put them end to end and make a shaft. There is enough room on the 'shaft' for the bearings and pully. After that is together I will build a base out of scrap wood and mount it to the wall with a spare motor to get it spinning. I figure if I get the rpms up past 3k it will cut like any other hard diamond wheel. I should have this whole thing built and cutting for about 60 bucks which is what that parts list cost including shipping.
aGates
Post by aGates on Jun 22, 2024 0:31:12 GMT -5
aGates , I am going to use the coupler to put them end to end and make a shaft. There is enough room on the 'shaft' for the bearings and pully. After that is together I will build a base out of scrap wood and mount it to the wall with a spare motor to get it spinning. I figure if I get the rpms up past 3k it will cut like any other hard diamond wheel. I should have this whole thing built and cutting for about 60 bucks which is what that parts list cost including shipping. And I suppose will you use it as a fixed carving type deal or? I like the build I suppose my next question is application based Will you make cabs with it?
Post by cobbledstones on Jun 22, 2024 23:49:34 GMT -5
aGates yes I will try shaping cabs on it. because... 1) I think it will be an super cheap starter build, 2) I want to make some cabs with concave edges.
aGates
Post by aGates on Jun 23, 2024 11:51:43 GMT -5
aGates yes I will try shaping cabs on it. because... 1) I think it will be an super cheap starter build, 2) I want to make some cabs with concave edges. Awesome I look forward to the build and products brother!
Post by cobbledstones on Jun 29, 2024 19:36:31 GMT -5
now that I have the parts here, I like the single sided arrangement. I think the single bearing will be enough.
aGates
Post by aGates on Jun 29, 2024 20:13:59 GMT -5
What are your water dispensary and anti spray device thoughts
Post by Rockoonz on Jun 29, 2024 22:49:52 GMT -5
Bearing looks self aligning, which means when the torque of the pulley pulls the pulley it will pivot.
Post by 1dave on Jun 30, 2024 19:35:09 GMT -5
It looks handy.
