andyiii
Member since May 2024
Post by andyiii on Jun 21, 2024 19:52:13 GMT -5
Hello again all!
I've got my hands on a bit of rough stone labeled "blue amphibole" from Africa. Searching google, it is also apparently called "blue quartz", "blue angel phantom quartz", and "blue angelite".
Everything I can find says it is Mohs 5-6. These rocks "feel" softer, if you know what I mean.
I have only, thus far, tumbled harder rocks in the Mohs 7+ range. Before I destroy these, should I:
1) Shorten stage 1 (60/90 SiC), or even skip it entirely?
2) I plan to roll them in a 3-lb. rotary tumbler until smooth, then shift to vibratory. Since they are softer, I don't plan to mix in any other rocks, which means I need media to fill the barrel. Should I limit to plastic media only since it is "softer", or is ceramic just fine?
Any other tips?
Thanks, Andy III
titaniumkid
Member since June 2023
Post by titaniumkid on Jun 22, 2024 2:03:14 GMT -5
This might be useful.
andyiii
Post by andyiii on Jun 22, 2024 10:27:43 GMT -5
Cool! Thanks - I tried like 10 different search terms and didn't come up with a good result, but didn't try "angelite" since it seemed like a very uncommon name for the stones ...
