Post by stardiamond on Jun 26, 2024 12:43:49 GMT -5
When material is too expensive for me to buy, I look for opportunities. A FB seller who I have bought from before offered a 10 pound parcel from a collection he bought. It wasn't cheap but affordable. The seller was honest that a lot of the material was land fill and that extracting cabable material would require trim saw work. I bought it and when it arrived, I sorted it and ended up with 3 1/2 pounds to explore and 6 1/2 pounds of landfill. One of the pieces weighs 4.75 ounces and is a face polished piece of Deschutes or Blue Biggs rough. Next step is abusing a trim saw blade. Part of the fun with the hobby is trying to make something out of not much.
Post by stardiamond on Jun 29, 2024 13:53:34 GMT -5
I reamed out the hole of a trim saw blade from 5/8 to 1 inch to get it to fit my trim saw. I made exploratory cuts on the pieces and they were either duds or regular Biggs. I bought over 10 pounds of Biggs from Tony so I already had a lifetime supply. One of the pieces was Blue Biggs or Deschutes but had no pattern except for the tip. The only positive is that I got off my butt and did some work.
khara
Member since September 2022
Post by khara on Jun 29, 2024 15:22:42 GMT -5
I don’t think I’d ever seen rough Biggs or Deschutes until now. Looks like some nice pieces. I hope you still feel you got a good deal after sorting the 6.5 lbs of yard rock out.
tribeunited
Not all materials look exactly the same. But all exact materials are exactly the same.
Member since May 2024
Post by tribeunited on Jun 29, 2024 15:22:53 GMT -5
This is cool! I like seeing them before and after, It makes the slabs make more sense. Thanks for sharing these!
Post by stardiamond on Jun 29, 2024 16:54:44 GMT -5
I slabbed the polished piece and can lay out three preforms, none of which is super exciting. In February, I bought a bag of Idaho seam agate from Tony (catmandewe). When I received the order it conatined, large, trim saw size and tumbling rough. Since the trim saw was set up, I cut a few slabs.
tribeunited
Post by tribeunited on Jun 30, 2024 13:51:54 GMT -5
OMG that first one.....STAAAAAAARRRRREEEEE. So that is Idaho Seam! WOW! catmandewe has some pretty fabulous stuff!!!
Post by stardiamond on Jun 30, 2024 14:24:39 GMT -5
I ground and dopped 4 preforms from this material, two Biggs and two ISA.
Post by stardiamond on Jul 1, 2024 16:54:23 GMT -5
It's close to 100. I work in the shade, but I'm done for the day. All through 1200 grit. I need to go back to 80 on the Deschutes to remove a pit. I'll finish the other seam agate, take a picture and toss it.
Post by stardiamond on Jul 2, 2024 12:48:06 GMT -5
ThomasT
Member since June 2022
Post by ThomasT on Jul 2, 2024 13:12:25 GMT -5
Mighty nice-looking pieces from a box of scrap.
