rockbrain
Member since January 2022
Post by rockbrain on Jun 29, 2024 16:05:35 GMT -5
I have the KN 6. Just got an order of new felt pads. I have to pull the water valve loose from the front to replace them. Does anyone know what the size of the set screw for the knobs are? I cleaned out the gunk and it looks like an allen hex. I've tried 1/16 which seems to be too small and 3/64 which appears to be too big. My smallest metric wrench doesn't work. Help.........
chris1956
Member since July 2022
Member is Online
Post by chris1956 on Jun 29, 2024 19:46:05 GMT -5
I have the KN 6. Just got an order of new felt pads. I have to pull the water valve loose from the front to replace them. Does anyone know what the size of the set screw for the knobs are? I cleaned out the gunk and it looks like an allen hex. I've tried 1/16 which seems to be too small and 3/64 which appears to be too big. My smallest metric wrench doesn't work. Help......... I haven't done it yet but need to. ??
Post by liveoak on Jul 1, 2024 6:39:13 GMT -5
I think we measured the set screws on mine as 6-32" X 5/32" long and a 1/16" allen hex key fits. I've had problems with the screws stripping out. I had better luck when we got a short NEW allen wrench.
I'm a little late, and I'm sure you already figured it out.
Of course, yours may be different.
Patty
rockbrain
Post by rockbrain on Jul 1, 2024 8:48:35 GMT -5
Thanks Patty, I haven't figured it out. I'm using a ball end 1/16 allen and it seemed to small. I'll try a different wrench.
Post by liveoak on Jul 1, 2024 9:13:34 GMT -5
Truthfully, I had a hell of a time until I got a new allen wrench. But I think I said that already.
Patty
Post by jasoninsd on Jul 1, 2024 22:22:12 GMT -5
I ended up using a micro-screwdriver...that just "happened" to fit the space in the hex...
khara
Member since September 2022
Post by khara on Jul 2, 2024 2:07:10 GMT -5
These manufacturers would be really smart to sell a small tool kit that has everything you need to do basic maintenance on their machine.
PS I’ve been eyeing new felt and now I’m thinking I’ll just put it off a bit longer.
dshanpnw
Member since December 2020
Post by dshanpnw on Jul 3, 2024 7:23:20 GMT -5
I have removed my water knobs several times to change the felt pads. It did take a couple tries with different allen wrenches before I found the right one which I am pretty sure is 1/16, and the closest metric would be a 2, I think. Anyway, the first time I took them off it seemed like I stripped one of the set screws because I used the wrong wrench, but once I found the right one it still worked fine. Once I found the right wrench I keep it solely for that machine and close by so I never have to guess again which is the right one. Just be careful not to strip those set screws or you'll have a heck of a time removing it somehow, and then you might find yourself in Ace Hardware searching for the correct tiny one. I think it would be difficult to find an entire knob exactly the same if you had to replace the whole thing. I cut my own felt pads the first time I replaced them and they wore out in days. I used what felt I had, hence the green. The second time I positioned them differently on the rubber guides and they are working well. The new felt pads KN offers are much better than the originals, I think.
I like Khara's advice to the manufactures to include the tools needed, or at least the sizes you would need.
chris1956
Member is Online
Post by chris1956 on Jul 3, 2024 7:51:02 GMT -5
I like Khara's advice to the manufactures to include the tools needed, or at least the sizes you would need. Thanks for the information.
rockbrain
Post by rockbrain on Jul 3, 2024 9:13:52 GMT -5
I guess I'm going to have to get a new 1/16 wrench and give that a try. I can understand the ball end of the one I have not working but it's not like there's a lot of wear on the one I have.
dshanpnw
Post by dshanpnw on Jul 3, 2024 19:42:26 GMT -5
I guess I'm going to have to get a new 1/16 wrench and give that a try. I can understand the ball end of the one I have not working but it's not like there's a lot of wear on the one I have. It might not be 1/16, but it fit into the 1/16 slot of the allen wrench holder, so I assume it was correct. The size is not stamped on it.
