Post by cabby on Jul 18, 2024 15:12:50 GMT -5
Dud?
Jul 18, 2024 16:17:35 GMT -5
Post by pebblesky on Jul 18, 2024 16:17:35 GMT -5
The first piece, which looks like a sandstone to me, are the patterns only on the surface just like a two dimensional "print"? The patterns aren't interesting enough anyway, probably not worth slabbing to check further.
realrockhound
Chucking leaverite at tweekers
Member since June 2020
Member is Online
Dud?
Jul 18, 2024 16:24:09 GMT -5
via mobile
cabby likes this
Post by realrockhound on Jul 18, 2024 16:24:09 GMT -5
For lack of better words, yes, #1 is basically a dud. If you tried to cab it etc.. you’d lose the dendrites and color. I have a lot of that stuff laying around the property
Post by cabby on Jul 18, 2024 16:28:08 GMT -5
For lack of better words, yes, #1 is basically a dud. If you tried to cab it etc.. you’d lose the dendrites and color. I have a lot of that stuff laying around the property Thanks! Does make me wonder why he bought it, though… any idea what it’s a dud of?
realrockhound
Member is Online
Dud?
Jul 18, 2024 16:59:51 GMT -5
via mobile
Post by realrockhound on Jul 18, 2024 16:59:51 GMT -5
For lack of better words, yes, #1 is basically a dud. If you tried to cab it etc.. you’d lose the dendrites and color. I have a lot of that stuff laying around the property Thanks! Does make me wonder why he bought it, though… any idea what it’s a dud of? what it is, is either a limestone or a sandstone. Generally, there might have been a face to that piece that had a crack all the way across the face, manganese goes through that crack and makes the dendrites. But they are only face value and don’t go into the stone. Sometimes you can get some pretty cool ones that are just a neat piece to have. Nothing you can do with them other that admire the features that grew on the rock.
realrockhound
Member is Online
Post by realrockhound on Jul 18, 2024 17:01:29 GMT -5
Dud?
Jul 18, 2024 17:11:03 GMT -5
via mobile
Post by cabby on Jul 18, 2024 17:11:03 GMT -5
Ok, so it’s not that it’s a dud of a specific type of picture “jasper”,… it’s just a different type of picture stone? I have been working under the assumption that all of my searches should start with “jasper” lol
Edit: realized why I assumed this limestone would be called “jasper”… had previously run across Chinese picture jasper and got it into my head that dendritic limestone will be called jasper, too 😓
Post by pebblesky on Jul 18, 2024 17:23:52 GMT -5
I agree Chinese picture stone shouldn't be called jasper. A more accurate name I see recently is Chinese Dendritic Limestone.
realrockhound
Member is Online
Dud?
Jul 18, 2024 17:24:56 GMT -5
via mobile
Post by realrockhound on Jul 18, 2024 17:24:56 GMT -5
Ok, so it’s not that it’s a dud of a specific type of picture “jasper”,… it’s just a different type of picture stone? I have been working under the assumption that all of my searches should start with “jasper” lol Edit: realized why I assumed this limestone would be called “jasper”… had previously run across Chinese picture jasper and got it into my head that dendritic limestone will be called jasper, too 😓 Names get thrown around super Willy nilly. I wouldn’t even call it a picture stone. Just a dendritic sandstone etc…
realrockhound
Member is Online
Post by realrockhound on Jul 18, 2024 17:27:47 GMT -5
There is a lot of material out there in general that I personally wouldn’t even call true dendritic material. Only reason it gets called that is because the formations look like your traditional black dendrites which are manganese. But I’m overly critical so what the hell fo I know 😂
Post by chris1956 on Jul 18, 2024 18:19:39 GMT -5
I agree it is probably sandstone or limestone. I pick up a lot of creek and beach rocks that I don't know if they will polish or not but look interesting. Before I slab it, I try polishing a spot that I can get to on the wheels to make sure it will polish well. Then decide depending on how well or not it polished.
Post by cabby on Jul 18, 2024 18:41:12 GMT -5
For actual picture jasper and “jasper”, are the typical scenes (what I see in books and online) just straight across cuts, or will they need fancy angles to recognize them?
realrockhound
Member is Online
Post by realrockhound on Jul 18, 2024 20:18:52 GMT -5
For actual picture jasper and “jasper”, are the typical scenes (what I see in books and online) just straight across cuts, or will they need fancy angles to recognize them? The picture jaspers you see online will carry the pattern all the way through the stone in most cases
