wargrafix
Member since June 2023
Post by wargrafix on Jul 21, 2024 19:31:01 GMT -5
Hey all, so my wife surprised me by ordering both a large and medium box geodes from the gem shop. The last time the collective weight was 5pound and had some agate geodes. This one is 7 pounds. Generally the gem shop boxes tend to be nice in terms of geode cavities. While it might mean most of the geodes are filled, is there a senario where a heavy weight is in a geodes favor?
titaniumkid
Post by titaniumkid on Jul 22, 2024 17:22:51 GMT -5
I have no answers but your wife is a star
wargrafix
Post by wargrafix on Jul 22, 2024 17:27:34 GMT -5
I have no answers but your wife is a star Yup, she is. I want to buy a thin 7 inch tike saw blade. Continuous. The segmented ones carry risk that I don't think my wife would bear.
Post by vegasjames on Jul 22, 2024 20:03:09 GMT -5
I would say yes. Although it would depend on where the geodes originated from, and thus there mineral make up. Geodes from Indiana and some I got from Kentucky for example seem to be a lot less silcated, and often solid. They seem softer like maybe more calcium based. If the geodes are from an area known for agate or quartz crystals inside, the silicates would give the geode a higher density.
What would be interesting to experiment with is tapping the geodes with a metal object like a rod and learning the sound differences as a hollow geode would transmit sound differently than a solid geode.
Post by vegasjames on Jul 22, 2024 20:06:01 GMT -5
I have no answers but your wife is a star Yup, she is. I want to buy a thin 7 inch tike saw blade. Continuous. The segmented ones carry risk that I don't think my wife would bear. A 7 inch blade will not give ou much of a depth of cut as generally the blade only goes about 1/2 inch above the table.. I recommend getting a 10 inch tile saw. Continuous rim blades are easy to find for these, and they will give ou a much deeper cut, around 4 inches.
wargrafix
Post by wargrafix on Jul 23, 2024 0:30:09 GMT -5
I am in full agreement, but right now it's the saw I have. :-(
wargrafix
Post by wargrafix on Jul 23, 2024 0:33:30 GMT -5
Today is little one's birthday and I will wrap those boxes as additional gifts. She loves rocks and geodes. We are going to have alot of fun
wargrafix
Post by wargrafix on Jul 23, 2024 12:20:57 GMT -5
Correction. Gem center USA
Post by rmf on Jul 23, 2024 19:22:58 GMT -5
wargrafix if you want to open a geode and your saw is not big enough, and you do not need to have a sawed face then go to Home Depot and rent a soil pipe cutter and use it to crack the geode. It will make a nice "as smooth as you can get without a saw" fracture of the geode.
wargrafix
Post by wargrafix on Jul 23, 2024 19:32:44 GMT -5
wargrafix if you want to open a geode and your saw is not big enough, and you do not need to have a sawed face then go to Home Depot and rent a soil pipe cutter and use it to crack the geode. It will make a nice "as smooth as you can get without a saw" fracture of the geode. Alas I am not in the US and there are no soil pipe cutters. I have spoken to ppl in the oil industry and they looked at me with confusion on what a soil pipe cutter was.
The pull technique of the saw...do you all roll the rock away from the blade, or into the spin?
Post by rmf on Jul 25, 2024 7:49:23 GMT -5
Check with plumbing people. a "soil pipe" cutter is for cutting cast iron sewer pipe. so it is soil pipe as in "night soil" ... people excrement used for fertilizer.
wargrafix
Post by wargrafix on Jul 25, 2024 10:05:26 GMT -5
Check with plumbing people. a "soil pipe" cutter is for cutting cast iron sewer pipe. so it is soil pipe as in "night soil" ... people excrement used for fertilizer. You would think so....... Their solution for everything? "Use a hacksaw"
Post by Fossilman on Jul 27, 2024 15:30:40 GMT -5
wargrafix if you want to open a geode and your saw is not big enough, and you do not need to have a sawed face then go to Home Depot and rent a soil pipe cutter and use it to crack the geode. It will make a nice "as smooth as you can get without a saw" fracture of the geode. Alas I am not in the US and there are no soil pipe cutters. I have spoken to ppl in the oil industry and they looked at me with confusion on what a soil pipe cutter was. The pull technique of the saw...do you all roll the rock away from the blade, or into the spin?
Chain pipe cutter would do the trick too, we used them in the oilfields in Montana and North Dakota...
wargrafix
Post by wargrafix on Jul 27, 2024 17:37:54 GMT -5
Chain pipe cutter would do the trick too, we used them in the oilfields in Montana and North Dakota... I talked to several ppl in the oil industry and they have no idea what it is or if they do, the company never bought one. Trinidad kinda backwards
wargrafix
Post by wargrafix on Jul 27, 2024 17:41:14 GMT -5
I bought the qep glass blade. Glq version
