sift
Member since June 2024
Post by sift on Jul 24, 2024 4:43:46 GMT -5
Hi all,
I'm 8 days into the polish stage in my rotary. There were 3lbs of rocks in the barrel, along with ceramic media and plastic beads.
I've just realised that I only put 4 tablespoons of grit in. Should I stop the run to assess and add more grit or just let it continue? How long for?
Thanks in advance. Happy tumbles...
waterboysh
Member since April 2021
Post by waterboysh on Jul 24, 2024 7:25:17 GMT -5
4 Tbsp is plenty in a 3lb barrel. Probably only really need 3. Also, 8 days is generally long enough for each stage after coarse... though I do tend to let my polish stage run for 2 weeks when I'm using my rotary tumbler. It generally doesn't hurt anything to run longer.
Post by jasoninsd on Jul 24, 2024 22:33:56 GMT -5
I agree with the above. I'd let it run it's normal stage run. If you don't like the results...you can always run any of the stages again...including the polish stage...
