wargrafix
Member since June 2023
Post by wargrafix on Aug 5, 2024 15:51:19 GMT -5
Hi all, geodes and cleaned and a new blade is one the way. I am requesting some advice. One of the rocks feels very light and I think the wall might be thin. What is a cutting strategy I could use to not blow out the geode?
rocknrob
No matter what AI thinks, I do not in any way resemble John Malkovich
Member since May 2024
Post by rocknrob on Aug 6, 2024 18:52:00 GMT -5
You could try to do the rotate cut method that you see some folks do on Youtube. It's a bit trickier since you're using a tile saw which would be running faster than a lapidary saw (assumedly). By "Rotate cut" I mean you cut 2/3-3/4 of the way through and then gently rotate the uncut portion into the blade. There is a chance the saw might be too hard on the geode though so if you don't have a resource where you can use a lapidary saw, I would go extra slow and gentle.
- Rob
wargrafix
Post by wargrafix on Aug 7, 2024 7:05:05 GMT -5
Post by amygdule on Aug 7, 2024 7:24:21 GMT -5
Try mounting it in a cube of Plaster of Paris
wargrafix
Post by wargrafix on Aug 7, 2024 9:54:19 GMT -5
Try mounting it in a cube of Plaster of Paris Ohhhhhh......that's very interesting. It will provide a buffer block and more area to hold?
rocknrob
Post by rocknrob on Aug 7, 2024 11:14:18 GMT -5
wargrafix
Post by wargrafix on Aug 7, 2024 12:34:46 GMT -5
The last package was about 4 pounds and the medium was 3 pounds.
No doubt its pricy but its my second foray into ordering geodes in terms of sources. The Nat geo stuff is crap. This one has good variety. Of course if there are better variety source i am all ears! I have to take a picture of the set. Its a mixture of Moroccan, Mexican and US geodes.
I know it sounds picky, but morroccan geodes are boring. Mexican have the best chance of being something interesting. Keokuk and dugway can be 50/50 with this selection
Post by amygdule on Aug 7, 2024 15:23:23 GMT -5
Try mounting it in a cube of Plaster of Paris Ohhhhhh......that's very interesting. It will provide a buffer block and more area to hold? Yes, the plaster will help support the thin, fragile wall of the geode. Here's a couple of pix. A natural example of a fossil clam geode embedded in mudstone. Lined with calcite and quartz crystals. Found as is tumbling in the surf.
wargrafix
Post by wargrafix on Aug 8, 2024 10:48:19 GMT -5
I will give it a shot.
What are better geode sources I should be checking for good variety?
Post by HankRocks on Aug 8, 2024 12:40:45 GMT -5
I will give it a shot. What are better geode sources I should be checking for good variety? Just wondering, the Geodes you have bought, were they guaranteed hollow? And what was the diameter range? Henry
wargrafix
Post by wargrafix on Aug 8, 2024 13:16:12 GMT -5
All of the geodes I cut from them (This is my 3rd set of large and medium and large, 3rd not cut as yet) have been hollow. golf ball to racquet ball size, no actual dimensions. I will give them udos where variety is concerned and all have presented interesting surprises in terms of a new type every time
wargrafix
Post by wargrafix on Aug 9, 2024 8:02:14 GMT -5
Here are all 24
rocknrob
Post by rocknrob on Aug 9, 2024 11:01:45 GMT -5
Here are all 24 Wow, that is a decent spread!
wargrafix
Post by wargrafix on Aug 9, 2024 16:10:40 GMT -5
Here are all 24 Wow, that is a decent spread! I am hoping it's really good
wargrafix
Post by wargrafix on Aug 11, 2024 20:59:59 GMT -5
It was alright. The new blade was alright but my cutting technique only started to improve too late. Some had nice crystal inclusion but nothing that wowed me. I think I am an agate geode person. Here is the cut stuff
