Post by stardiamond on Aug 8, 2024 16:12:03 GMT -5
I buy super seven specimens on eBay. I look for some gold color which is cacoxenite. Flattened the bottom and drew the largest shape that would fit. 55mm length
Super 7
Aug 8, 2024 16:39:30 GMT -5
Post by tribeunited on Aug 8, 2024 16:39:30 GMT -5
Wow, gorgeous! I hope to find some of this material in my collection, it's so pretty. The cabs almost look like they would be translucent, but so much depth of color. Thanks for sharing these
johnthor1963
Cattle dogs rock
Member since June 2023
Super 7
Aug 9, 2024 7:20:24 GMT -5
via mobile
Post by johnthor1963 on Aug 9, 2024 7:20:24 GMT -5
Wow that turned out fantastic. It showed a lot of potential in the rough stage and you found the rest in the final stages. How did you flatten the bottom of the stone? I practice a lot with tumbling rough and I use a magnetic flat discs to flatten them out after I grind on my 60grit wheel. Very nice piece you sure have an eye for material. Thx for sharing
Post by stardiamond on Aug 9, 2024 10:19:09 GMT -5
Same technique with textured 80 grit and an 80 grit flat lap which is worn.
