flyingweisel
Member since April 2024
Post by flyingweisel on Aug 17, 2024 13:41:07 GMT -5
i have a Star Diamond 6 inch combo unit i am rebuilding. i have not got the new wheels yet but it does have a good saw blade. the original wheels were silicon carbide and they were chipped and i did not want to risk them shattering on me while i try to use them. can i use the saw blade without the wheels on it?
rockbrain
Member since January 2022
Post by rockbrain on Aug 17, 2024 16:42:01 GMT -5
I don't think it should be an issue. Some of those look like they're set up with an expanding drum on the end. You didn't mention it but if you do happen to have one of the rubber drums you aren't supposed to run those without a belt on them.
flyingweisel
Post by flyingweisel on Aug 17, 2024 19:04:17 GMT -5
My machine doesn't have an expandable drum, just 2 silicon carbide wheels, a side plate for polishing and a saw. It's good to know I wind damage anything if I use it as just a trim saw for a bit.
flyingweisel
Post by flyingweisel on Aug 22, 2024 6:58:57 GMT -5
I don't think it should be an issue. Some of those look like they're set up with an expanding drum on the end. You didn't mention it but if you do happen to have one of the rubber drums you aren't supposed to run those without a belt on them. here is a picture of what mine looks like though this is not my unit. i found the picture of what it looks like on the internet.
