vpkeebs
Member since September 2024
Post by vpkeebs on Sept 3, 2024 6:01:46 GMT -5
Hello,
Im from central Minnesota and found this awesome community of rock hounds. I have tumbled some rocks in the last couple years but don't have a ton of knowledge. I think what I find the most difficult is determining what rock I have and it's hardness. I pick up anything my minds says "that's a neat looking rock" with all intentions of tumbling them and I hit a wall as I don't want to ruin them by tumbling with a non compatible hardness(I have like 80lbs sitting...waiting...to tumble?). Here to learn everything I can.
Post by rockjunquie on Sept 3, 2024 6:48:46 GMT -5
Welcome aboard from Virginia.
Post by vegasjames on Sept 3, 2024 7:12:30 GMT -5
Welcome from Southern Nevada.
Post by liveoak on Sept 3, 2024 7:28:30 GMT -5
Welcome from NW Florida
Patty
Post by chris1956 on Sept 3, 2024 8:19:48 GMT -5
rocknrob
If Costco only sold slabs in bulk...
Member since May 2024
Post by rocknrob on Sept 3, 2024 8:35:19 GMT -5
The hardest thing (aside from diamond) I have is finding enough softies to go together for a good tumble. Yes, that pun was intended and no... I'm not sorry about that one. Welcome from Washington State!
Post by cabby on Sept 3, 2024 8:52:29 GMT -5
Welcome from Wisconsin! I live on a moraine so I know exactly what you are talking about! It’s not so easy to identify your rocks when A) they are well weathered and B) you don’t have the first clue where the material came from. Hardness testing is useful for rocks that are primarily single mineral (like agates) but not as useful for things with a mix of minerals (unakite) since it’s hard to test the individual minerals. I found that visually examination with magnification is more useful for most of my rocks. If you are picking up well worn material like you see at Lake Superior you can learn to identify common things visually. If your rocks have a weathered crust like what I dig or find in gravel, you will need to open them up since the material on the rind is often different from what is inside. You can use a cheap tile saw to cut a piece off to see inside, which also gives you a flat face to do hardness testing. I use a hammer or another rock to break the piece I cut off, which lets me see what shapes the minerals make to compare to mineral guides. The UW has a site that lists minerals found in the state with each mineral also having a list of known counties (my county isn’t well surveyed, sadly). UofM probably has something similar you can reference. Good luck! Glacial gravel is a bugger to identify, but eventually you will get used to what things you find frequently and what they look like (for you), and not need to test each one every time.
zebra61
Member since January 2024
Post by zebra61 on Sept 3, 2024 12:01:17 GMT -5
Hello from NORTHERN Minnesota! Welcome to the RTH Forums. I've got several buckets full of 'OTLN' rocks and can only identify about 5 to 10% of them. You're in pretty good company! (Oh That Looks Neat)
python
Member since June 2024
Post by python on Sept 3, 2024 19:09:45 GMT -5
Welcome!
Post by drocknut on Sept 5, 2024 10:16:06 GMT -5
Welcome to the forum from NW Arizona
Post by jasoninsd on Sept 5, 2024 11:44:24 GMT -5
Hey Nick! Welcome to the forum from South Dakota!
RockNerds
oooooooooo a rock lol
Member since August 2024
Post by RockNerds on Sept 6, 2024 13:17:41 GMT -5
Glad to have found this community also, great to be surrounded with like minded people Ryan from Michigan
