Post by chris1956 on Oct 11, 2024 16:30:20 GMT -5
Here are a few I tumbled with the Lot-O polished art glass that I posted pics of earlier. I liked the way the "green tree agate" turned out, especially the tree. The dark ones are sadolite and the guitar pic is the "maybe" basalt and quartz from the rock I found in Michigan this summer. Thanks for taking a look, Chris
Post by velodromed on Oct 11, 2024 18:46:59 GMT -5
I like those! I’ve been needing to break out my saw again. Something along these lines would be nice to try. Thanks for sharing!
Post by whalecottagedesigns on Oct 11, 2024 19:24:48 GMT -5
The trees are great but I really dig that star!
Post by chris1956 on Oct 11, 2024 20:49:08 GMT -5
I like those! I’ve been needing to break out my saw again. Something along these lines would be nice to try. Thanks for sharing! Thanks. And you are welcome. The trees are great but I really dig that star! Thanks. I think I have a few other stars somewhere. Will see if I can find them and post. Need to make some more.
Post by pebblesky on Oct 11, 2024 21:39:21 GMT -5
It is a great choice to use the moss agates for trees!
python
Member since June 2024
Post by python on Oct 11, 2024 22:49:29 GMT -5
Very nice! I also really like the tree agate for the tree. Well done!
Post by liveoak on Oct 12, 2024 6:17:36 GMT -5
Nice ones. The trees are a great addition, and the star came out perfect ! I'm going to have to try a tree. I'm thinking, you're top drilling them to hang up ?
Thanks for the inspiration,
Patty..... with turtles in the tumbler
Post by chris1956 on Oct 12, 2024 8:16:07 GMT -5
Very nice! I also really like the tree agate for the tree. Well done! Thanks!
Post by chris1956 on Oct 12, 2024 8:29:04 GMT -5
Yes liveoak, I typically drill the top which takes some careful drilling to get started. I usually (against most advice you hear) go straight at the top. You have to make sure you have it exactly centered on the top. I use a Dremel drill press (and put the tree in a small jewlers vice) and go very slowly until I can hear the bit just touch the surface. Then continue going very slowly until there is enough of a depression that the bit won't slide off the side. I put a picture of one with an eyepin below. The tree in this post (green tree agate above) is very thin so I will probably make it into a refrigerator magnet.
Post by liveoak on Oct 12, 2024 8:42:21 GMT -5
Thanks for the tips, Chris. Sounds a little nerve racking - but you obviously have it down Patty
Post by orrum on Oct 12, 2024 10:15:55 GMT -5
Love those!!!
mdjunkie
Member since November 2023
Post by mdjunkie on Oct 12, 2024 12:48:50 GMT -5
Great work, I love these ornaments!
Post by chris1956 on Oct 12, 2024 12:59:25 GMT -5
You are welcome. Can be nerve racking. I use small bits 1 or 1.1 mm diameter. I had been using cheap bits but if you go too fast or burn out the diamonds, it is really easy to melt the shaft and leave the drill bit in the hole. Nothing you can do at that point. I recently switched to Crystalite Triple Ripple Drills and they seem to work much better (5X the cost) at least in the small sizes where it is easy to heat up the shaft and melt it. Since you are dealing with small holes, I try to twist or crimp the eyepin so the epoxy holds on to it better. Thanks. Great work, I love these ornaments! Thanks.
Post by jasoninsd on Oct 12, 2024 15:30:32 GMT -5
Chris, you got this down to a science! I gotta agree that the Green Moss Agate makes killer looking trees!
Post by tribeunited on Oct 12, 2024 15:50:30 GMT -5
I agree on those tree ornaments being something special! I'm so glad you posted more ornament photos!!! Everyone needs to see these little cuties!
Post by chris1956 on Oct 12, 2024 18:11:15 GMT -5
Chris, you got this down to a science! I gotta agree that the Green Moss Agate makes killer looking trees! Thanks. I agree on those tree ornaments being something special! I'm so glad you posted more ornament photos!!! Everyone needs to see these little cuties! Thanks.
dshanpnw
Member since December 2020
Post by dshanpnw on Oct 13, 2024 9:23:54 GMT -5
Very nice chris1956, I love them. The green tree agate is perfect! Thanks for sharing.
Post by chris1956 on Oct 13, 2024 11:38:26 GMT -5
Very nice chris1956 , I love them. The green tree agate is perfect! Thanks for sharing. Thanks.
dustys
Member since October 2024
Post by dustys on Oct 15, 2024 14:36:06 GMT -5
The trees are wonderful
Post by chris1956 on Oct 15, 2024 16:56:10 GMT -5
