birdie
Member since September 2024
Post by birdie on Oct 20, 2024 15:09:19 GMT -5
Some of the rocks I've picked up have such skinny/deep crevices that no matter how I try, or what I use (so far), I just can't clean them properly. What method(s) you use? Thank you!
Post by vegasjames on Oct 20, 2024 16:24:30 GMT -5
I clean a lot of my tumbling material by simply throwing them in a large tumbler or cement mixer along with all the chips from breaking up the rocks. The chips act like a grit grinding off caliche, lichens, etc. and there will some grinding of the stones.
I have even got polished stones from tumbling in just water alone, but I find the rhyolites do best for this process. With no grit, the stones also keep more of their natural shape rather than rounding.
birdie
Post by birdie on Oct 21, 2024 16:20:40 GMT -5
Thanks, James!
birdie
Post by birdie on Oct 21, 2024 18:33:50 GMT -5
Anyone else have any methods? I have used various small brushes, toothbrushes, denture brushes, and various natural cleaners. However, some of these cracks are so thin! Has anyone tried hydrogen peroxide, or even bleach?
Post by pebblesky on Oct 21, 2024 19:05:32 GMT -5
Have you tried acid? Maybe start from soaking the stones into some coke since it is safe.
Post by whalecottagedesigns on Oct 21, 2024 19:24:11 GMT -5
The idea of the coke set me thinking, I am using an ultrasonic cleaner to clean out polish on my cabs, and as some folks said they were hesitant as they worried about the ultrasonic cleaner breaking up their rocks, as a test I am doing it on everything! And so far, I have not had a breakage. So the ultrasonic, fingers crossed, so far is safe enough to use from what I can see.
Perhaps using coke or vinegar or lemon juice in an ultrasonic would help in this sort of situation?
Post by vegasjames on Oct 21, 2024 20:17:09 GMT -5
The idea of the coke set me thinking, I am using an ultrasonic cleaner to clean out polish on my cabs, and as some folks said they were hesitant as they worried about the ultrasonic cleaner breaking up their rocks, as a test I am doing it on everything! And so far, I have not had a breakage. So the ultrasonic, fingers crossed, so far is safe enough to use from what I can see. Perhaps using coke or vinegar or lemon juice in an ultrasonic would help in this sort of situation? All depends on the stones. Opals for example generally should not be put in ultrasonic cleaners.
And some stones can be stained by Coke or dissolved by the acids in it, such as phosphoric acid.
Post by whalecottagedesigns on Oct 21, 2024 21:05:09 GMT -5
Agree strongly! Horses for courses
birdie
Post by birdie on Oct 22, 2024 19:23:56 GMT -5
I hadn't thought about vinegar, but I do use it for so many other purposes! My grandpa used to clean his pocket change in Coke every night, so I see where that would make sense!
WhiskeyZero
Member since December 2017
Post by WhiskeyZero on Oct 23, 2024 7:49:15 GMT -5
I mostly collect agates, jaspers, and pet wood in western CO and Utah. When I bring something home that is too pitted, cracked, etc., I'll see if it might be a good candidate for slabbing and polishing with my vibratory flat lap. If they don't look good for that they get tossed into the rings around the fire pit in my backyard. My fire pit is surrounded with agates, jaspers, and partially tumbled stones that I decided wouldn't be worthwhile to finish tumbling. I'd like to start making cabs with some of that material one day.
rockbrain
Member since January 2022
Post by rockbrain on Oct 24, 2024 8:53:45 GMT -5
I have to agree with WhiskeyZero. You have to pick stones that are suitable for tumbling. Stones with deep cracks and fissures really aren't. I also don't see an ultrasonic cleaner causing any damage that wouldn't be caused in a tumbler.
