Post by leisa on Nov 2, 2024 9:29:52 GMT -5
I have a Harbor Freight 7" wet saw. Unfortunately, I had two MK 303 blades become not usable in a very short amount of time. (Wouldn't cut - primarily jasper, agate, beach rocks). I wrote the company from which the blades were purchased. After looking at pictures of the blades that I had sent them, they kindly took the time to call MK Diamond Products to get their opinion. This is the message they sent me:
They said:
1.) The blade shaft RPM of 3400 on the 7" Chicago Electric is too high for this blade.
The recommended rpm for the 303 series is (2460 to 3270). This higher speed can cause the blade to overheat, thus the black scaring on the steel core.
2.) Cutting Jasper, Agate and Beach Rock (items that are higher on the Mohs scale) may require the use of lubricants other than water.
3.) Cutting without fresh lubricant/water and circulating the lubricant with recycled lubricant can also adversely affect the blade.
a) My brother is trying to help and wondered if something like a Harbor Freight Router Variable Speed Controller would help. (Sorry - I don't understand how this works with regards to the wet saw. My brother is not currently home, so I cannot ask him).
b) They mention buying a better wet saw. Do you have recommendations? I have no idea what a "better" one would cost.
c) Does anyone use a "lubricant" other than water when using a wet saw? I do keep the tray that came with the wet saw full of water, but it does use "recycled" water.
Thank you in advance for taking the time to read this. I apologize for asking so many questions.
Leisa
Leisa
