Post by kennychromedome on Nov 4, 2024 21:54:35 GMT -5
After an exhaustive search here...I could not find the answer.
I just bought a Vacuum Chamber and Cactus Juice to stabilize rocks and rock slabs.
Question:
After cutting a Rock into a smaller piece…and/or a slab, using mineral oil in my saw…does the mineral oil, now soaked into the piece affect the resin that would be vacuumed into the rock/slab?
If yes...would appreciate recommendations on how to extract the mineral oil.
realrockhound
Chucking leaverite at tweekers
Member since June 2020
Post by realrockhound on Nov 4, 2024 23:41:20 GMT -5
Always put your slabs in kitty litter for a few days after you slab them. Helps suck the oil out and return them to natural color quicker.
Post by Rockoonz on Nov 5, 2024 0:11:43 GMT -5
After kitty litter, a soak in a good degreaser, and a good rinse, the best way to remove any remaining residue is heat, but the flash point for the oil, usually about 300F, may also change the material color. In that case maybe a soak in acetone?
Post by rockjunquie on Nov 5, 2024 0:33:51 GMT -5
Welcome to the forum!
Definitely use the kitty litter and degreaser, but also make sure the slab is DRY.
rockbrain
Member since January 2022
Post by rockbrain on Nov 5, 2024 10:01:36 GMT -5
I've not stabilized yet but I've read to soak in water with Dawn dish soap for a few days.
Post by chris1956 on Nov 5, 2024 10:07:07 GMT -5
I always try to stabilize the rock before sawing to avoid the issue entirely. However, I sometimes wonder if that limits how far in the resin goes when in the vacuum chamber.
Post by roy on Nov 5, 2024 14:49:50 GMT -5
go to thrift store get you a cheap used toaster oven bake off your rock at 250 till it stops smoking about a hour or two then let cool do a final wash with soap and water put back in oven at 200 for a hour gets all the water out put in foil the a zip lock bag push out all the air when your ready pull out and put in the juice remember that you leave the vacume pump on till no bubbles come out turn off pump and release vacume let sit and soak for at least 2 days before baking at 220
