SirRoxalot
Member since October 2003
Post by SirRoxalot on Oct 12, 2003 15:58:10 GMT -5
What's the rule for tumbling larger stones? I've got some good solid amethyst chunks, 3-5", that are too nice to smash up. How many can I safely put in a 12 pound tumbler, mixed with a regular load of ~ 1" amethyst for filler? Do I need to worry about the big ones bashing everything else? Any point grinding down the big boyz edges first on a diamond wheel to speed things up?
Post by docone31 on Oct 13, 2003 7:51:01 GMT -5
I routinely put larger stones in with my small stones. I do not use too many they do not polish well that way. Sometimes I have to run the larger stones twice in the coarse grit. The smaller stones do not seem to shatter, but I do load larger with the larger stones. I run the bbl taller than usual. Grinding down the corners and fractures will control the shape better however. Good luck, amythyst is my birthstone.
WilliamC
Member since August 2003
Post by WilliamC on Dec 14, 2003 20:02:01 GMT -5
Greetings All,
I'm also into putting some fist-sized stones into the 12 pounder and letting them go through multiple coarse grind stages to get them shaped enough to polish. It just takes a lot of patience to do the larger stones, but I've finally gotten some pretty big ones ready to polish and they will be worth it when they are done.
WilliamC
Pdwight
Member since June 2003
Post by Pdwight on Dec 15, 2003 3:48:35 GMT -5
Strange you should ask, I am in the middle of that right now. I have my 12lb Model B loaded with many fist sized rocks and a few smaller ones. I have done 10 days at 40-60 grit. I had to recharge at 3 days...then I finished the first phase...boy did I loose a lot of mass.....that tumbler was 85% full when I started...now 50% at best. They smoother out well and now we are doing the 220 grit phase...I will keep you guys up on it.
Dwight P
Noah
Member since November 2003
Post by Noah on Dec 15, 2003 9:57:30 GMT -5
I cheated on my fist shaped rocks...I gave them some shape with a grinder then threw them into coarse for 2 days then, thre them quickly to 220 and then prepolish stage...then polish....Patience is something I still harp about with lol
-Noah-
