Post by hermatite on Oct 16, 2004 13:22:29 GMT -5
Okay...am I dumb or what? I got a saw given to me...cleaned it up...but it came with no instructions. Any idea how to get the coolant in? Do I just dump it in over the blade? and how much do I put in? Any help would be appreciated.
Post by krazydiamond on Oct 16, 2004 13:38:34 GMT -5
Post by hermatite on Oct 16, 2004 13:41:44 GMT -5
yes that's the one. sigh...everything I can find says "just and coolant and go"...that's not very helpful. I guess I'll have to see if I can find a number.
Post by sandsman1 on Oct 16, 2004 13:43:06 GMT -5
herm look for acouple screws in the top where the blade is and around the edges the top should come off because you will have to clean it out so there has to be a way in hahaha,, on my trim saw the plate comes off where the blade comes through allmost the whole top that you would lay a slab on to cut
Post by krazydiamond on Oct 16, 2004 13:45:41 GMT -5
as far as how much to add, once you get access to the pan, you will want to put in enough so that the blade is about 1/2" submerged......
KD
Post by sandsman1 on Oct 16, 2004 13:46:53 GMT -5
and for how much coolent all you need to fill is enuff to cover the bottom of the blade about 1/4 inch if you put too much it shoots out all over hahaha,, it will prob tak about a quart maybe less when you get the top off watch the blade when you fill it and stop at a 1/4 inch on the blade
Post by krazydiamond on Oct 16, 2004 13:51:06 GMT -5
i was erring on the side of caution there.....1/4" is probably the right amount, i use water and i add some in after it sits a while to cover for evaporation. my 6" Lortone take 5 quarts of water plus some coolant/anti-rust stuff.
go, Herm! KD
Post by hermatite on Oct 16, 2004 13:55:55 GMT -5
okay...can you all say DUH? I just called the guy who gave me the saw for advice. DUH. I'm off to cut! wish me luck.
Post by sandsman1 on Oct 16, 2004 14:13:59 GMT -5
KD your 6 inch saw takes 5 quarts you must have the new style saw fs-6 cause my ts-8 only takes like 2 quarts and its full ---well covering the blade 1/4 to 1/2 inch
Post by hermatite on Oct 16, 2004 14:26:02 GMT -5
oh...my...GOD! I had to run back upstairs to scream. THIS IS SO MUCH FUN!!!!! I CAN'T STAND IT!
Post by sandsman1 on Oct 16, 2004 14:36:50 GMT -5
hahahaha too funny herm ----it is aint it a whole new level with the rocks
Post by krazydiamond on Oct 16, 2004 15:10:12 GMT -5
that is great, Herm, yepper, jacking up the ol' addiction with bigger and better toys.....take some pictures sometime!
KD
Post by krazydiamond on Oct 16, 2004 15:12:23 GMT -5
oh, and yeh, Sands, it is the newer model, the top is hinged, lifts up and you pull the pan out like a drawer to empty and clean....i love it!
KD
Post by sandsman1 on Oct 16, 2004 16:47:16 GMT -5
yea you got the nice one when i clean mine i have to un screw it and carry the whole thing to the sink mines an old one but it still works good theres realy not much that can go wrong with them bearings or the shaft i just ordered that for my 10 inch saw when im done with that it will run like a new one again
Post by rockyraccoon on Oct 16, 2004 19:16:21 GMT -5
lol hermatite - i hope you'll show us pics of all the fun you are having.
kim
Post by cookie3rocks on Oct 16, 2004 19:54:06 GMT -5
I am SOOO envious I Will have a saw one day, I WILL! You can't have all the fun. ;D cookie
Post by Cher on Oct 16, 2004 20:23:25 GMT -5
Me too me toooooooo!!! LOL Herm, I'm so glad you're having a good time. Wish it was me, but someday. Can't wait to see some pics.
Cher
birdseed
Member since September 2004
Post by birdseed on Oct 17, 2004 2:29:34 GMT -5
The only draw back to Rock Rascal is that the Bearings are integral to the shaft..If the bearings go you have to replace the whole shaft(very pricey)--Also use more water than recommended--It is messy but the blades will last much longer..The coolant gets so dirty that more water is required the longer you use this machine--I have had a Rock Rascal model J for years and it still preforming well----
