Post by catmandewe on May 21, 2007 0:04:44 GMT -5
So I went to Portland and picked up a 30" saw this weekend, boy does it ever need some work. I was looking it over and it seems like if I mount a gas motor on it instead of the electric motor, I can control the speed of the blade easier. Anyone ever done this before? It came with a 2 hp 3 phase motor , but I dont have 3 phase power available. I do have a 1 1/2 hp 230 motor that I could put on it also. I have several different motors I can put on this and I do have a brand new 4 hp gas motor that I think I can just bolt up to it, and it has a variable throttle on it too. The saw came with a used blade and a new blade, theres a picture of them sitting on top of a 55 gallon drum. I stopped into visit my uncle and he had an old tumbler out in the barn that he gave me, its a cool old unit, it needs some work too, but it looks like I can get it to work.
Post by Deleted on May 21, 2007 0:52:35 GMT -5
We'll all be waiting to see the tumbled rocks!
Nathaniel
agatemaggot
Member since August 2006
Post by agatemaggot on May 21, 2007 0:57:11 GMT -5
I see some tubing running across the middle , are those for the oil supply ? I did'nt notice a pump in there.
dtcmor
Back to lickin' rocks again!
Member since May 2006
Post by dtcmor on May 21, 2007 1:54:42 GMT -5
Looks like you have your work 'cut' out for you! You're gonna have fun when you get it all up and running though!! I would try to keep it electric - the price of gas is going up quick!!
adrian65
Member since February 2007
Post by adrian65 on May 21, 2007 2:16:03 GMT -5
Wow that's quite a monster saw! I'm glad to see a resembling between my homemede saw and this one. In my opinion 1 1/2HP, meaning about 1 kW, is not enough for your saw. I would go for the 4 hp engine. But be carefull at the rotation speed corresponding to that power, it might be too big.
As far as I know, the optimum rotation speed of the blade is between 600 and 800 rot/min.
Please post some plate-size slabs when you'll cut them.
Adrian
Post by Deleted on May 21, 2007 6:27:03 GMT -5
Dude, If you get that thing to work I will personally send you a nice chunk of jade to slice from my collection. Good luck, we are all awaiting your results.
blarneystone
Rocks in my head
Member since March 2010
Post by blarneystone on May 21, 2007 6:35:01 GMT -5
Wow... that saw blade is huge! Seems like the clamp isn't big enough..lol. Good luck with the rebuild Cat. I think you will enjoy the project... I bought my saw used and did the rebuild myself.. very satisfying. Can't wait to see that beast up and running!
Dan
Post by creativeminded on May 21, 2007 7:12:46 GMT -5
That is a big saw, good luck getting it up and running. Tami
Post by joe on May 21, 2007 10:27:05 GMT -5
Ok, that's awesome! I hope you get it going.
Post by parfive on May 21, 2007 17:27:48 GMT -5
Catman - That's a cool saw you picked up!!! And it don't look that bad at all.
Use the 1 1/2 horse 230 motor - that's what comes on the Covington 30" saw, which happens to be on sale right now for $6500!!!!!!!!! I wouldn't waste my time with the gas motor.
I like your second pic because it shows how simple and basic the construction of a saw really is: a can with a frame inside to hold the arbor and sliding vise, and a motor. Now tell me a new one is worth 6500 friggin' dollars!
She'll be a beaut cleaned up.
Rich
Post by catmandewe on May 21, 2007 21:34:51 GMT -5
Hey..............Got it runnin today!!!!
Took a torch and cut out the cross vise assembly and welded in a new one made out of much heavier 3/4" grade 8 threaded redi bolt, now the table will move perpendicular to the saw blade as well as parallel. Made a mounting plate for the gas motor and bolted it up, it spins the blade just fine. Put new cables in for the weight feed system, and got all the pulleys to work. Headed to Twin in the morning to get 25 gallons of mineral oil, give her a whirl tomorrow. I will get some pics tomorrow. WOOOHOOOOO!!!!
Post by joe on May 21, 2007 23:21:07 GMT -5
That is SO cool! Good luck!!!! You can cut boulders with that.
Post by parfive on May 22, 2007 16:02:21 GMT -5
Hey Catman - Glad you didn't waste your time on that gas motor. Now I'm wonderin' how much of that 25 gallons ends up in the saw. ;D Rich
