Post by sandsman1 on Nov 29, 2004 19:54:54 GMT -5
i think thats what its called but anyway does anyone out there do milling i need new clamp pieces for my slab graber but i want to make them out of steel not aluminum cause i all ready messed them up hahaha
Post by krazydiamond on Nov 29, 2004 19:58:37 GMT -5
my hubby has a milling machine, but only does aluminium, do you have a drawing of what you need, Sands? we have a friend that does steel, can get you a quote. i just made his wife a necklace, so he owes me....haha.
KD
Post by sandsman1 on Nov 29, 2004 20:54:24 GMT -5
Post by docone31 on Nov 29, 2004 21:17:22 GMT -5
Sands, just use grout, or stucco and put the small pieces in. If you do go with a clamp, use either hard rubber, or lead in the jaws. Easier on the clamp. Your care package came. Beautiful work! How do you get them so flat, and the corners so sharp? Do you use a flat lap? I am going to send you some dumerite, and Royal Jade. I also have some real cool dumerite, real rare. The Royal jade is big bucks, so keep a good piece for your self. It has been estimated at 9$ a carat. If you have a flat lap, it is time you did some intarsia. You are definately up to it. Great work.
Post by sandsman1 on Nov 29, 2004 21:37:48 GMT -5
thanks doc i was hopeing they would get there fast --did you look at the slab grabber i posted it's so much faster then using plaster all ya do is when you cant cut any more you clamp that on the face of the rock you where just cutting and lock it in the saw vise with the rock clamped in it and start cutting from the other end of the rock i have been starting to buy more expensive rock i usta just throw the ends in a bucket but now some time i get a few more slices from something nice----i dont have a flat lap im hoping to make a deal with herm for that one she got from a friend im thinking i could use it for faceing bigger pieces--right now im useing 220 belt on a 8X3 inch drum and if you play with it just right they come out pretty good
i just ordered 8lb of spiderweb imperial jasper should get here this week--if its as nice as freda said ill make some and send them to ya,, i seen some on her site that looked real good
Post by docone31 on Nov 30, 2004 7:23:09 GMT -5
Cool. Wait untill you see what you can do with a flat lap! I use a 6" drum. I am really impressed with the results you get with a drum. With a flat lap, Intarsia!!! Lapidaryjournal.com has a tutorial on how to do it. I am also going to wrap one and send it to you. Might make a great gift for someone, or you might have a ball on Ebay.
Post by sandsman1 on Nov 30, 2004 13:34:14 GMT -5
doc i was looking at that intarsia and i got to say i think my fingers are too fat to do delacate work like that ---but who knows i might give it a try one day --cause i hate to say die before i give something a try hahaha---and doc i would never sell a gift,, what usually happens is i say hey chic look at this and in about 30 seconds i hear dad can i have this hahaha,, and of course she can have anything i got thats why i bought her a big jewlery box hahaha
Post by docone31 on Nov 30, 2004 18:00:10 GMT -5
John, I have seen your edges. They are good enough for intarsia. There is also no rule that says it has to be made just so. You could do it three sided, or five sided. The point is to join on a razor edge, then grind the joined pieced to a razor edge. The other trick the author did not write, is to use baking soda on the edges to be joined. Baking soda and CA also fill gaps so the joint does not need to be perfect. I do not know if epoxy could be used, the vibration of grinding might loosen the bond. You have razor edges freehand. Might have fun joining two pieces of stone and grinding them to a shape. I bet you could do it with the machines on hand.
Post by sandsman1 on Nov 30, 2004 18:13:00 GMT -5
maybe i was looking at the wrong thing doc i was looking at the small thin slices set into a dif stone i dont remember seeing two stones being joined --if you come across the link will you post it for me so i can take a look maybe i can doit without pullin the last little bit of hair outta my head hahaha
Post by connrock on Nov 30, 2004 18:21:13 GMT -5
Hey John,you have my addy send up to me. I'd be more then glad to do it for you. Tom ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Post by sandsman1 on Nov 30, 2004 18:31:06 GMT -5
yea i forgot you do that tom you sent me that cool punch,, that would be fantastic man when you see it you will see why i didnt wanna doit in aluminum again hahaha i beat the hell outta it haha i even got too close with the blade and shaved some off hahaha---hey tom thanks man,, i have lost touch with all my old friends since i got hurt--but thats the way it goes ---but i made a buncha new ones here
Post by docone31 on Nov 30, 2004 18:33:12 GMT -5
John, Intarsia, as done on stone, is slicing stone and glueing it to another. Take a pentagonal shape. The center stone would be cut into a pentagram. Thin slices would than be glued to the outside of the original pentagram. As each slice is glued on, it is evened up with the outside edge of the last piece glued. Say your inside pentagram is 12mm. 6mm slices would be glued to the outside of the original 12mm. You would have five slices. Once these have been glued and trued to the last piece, the next piece is glued on. Once the pentagram is 6mm thicker, then five slices of the outer stone are glued on. Once those five are glued on, the outer shape is made, and the cab is polished. Badabing, Badaboom, Intarsia! I have now seen your work first hand. You can do it freehand. A lap makes it easier to do. Basically, all it would entail is adding a border to one of your stones, and then another border. All stone Intarsia is done with a central cut, and layers added to make a pattern. Some Intarsia is backed. Basically, that would be adding a slab backing with epoxy. That epoxy works real well for. I have done that with good success. I have had a small piece of bloodstone, and backed it with feldspar. Than I ground it into a cab. It came out real well. I suspece, the slice from the diamond wheel is the right thickness for the border to the center. Try one, you will see.
Post by docone31 on Nov 30, 2004 18:34:58 GMT -5
Tom, you a machineist? I would love to make that faceter in Tips, but with a twist.
Post by connrock on Nov 30, 2004 18:35:40 GMT -5
I have a suggestion for you. When you use a clamp like yours it will work much better and last a lot longer if you put a block of wood the same size or a tad thiunner then you slab in the vice at the opposite end. This will give you a much better grip on the rock your cutting with out having to tighten it as much. The block of wood doesn't have to fit in the small grooves it the end of the clamp.You can put it in just a tad and it will work just fine. Tom ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Post by krazydiamond on Nov 30, 2004 18:42:52 GMT -5
like those Jorgensen clamps that MichiganRocks posted not so long ago??
wood does seem to be the medium Lortone uses on the big saw vises.....
my little hole drilling vise is all aluminum. the vise that came with my saw had some sort of fiberboard pieces to hold the stone...
KD
Post by sandsman1 on Nov 30, 2004 19:42:37 GMT -5
hey tom hold on to your seat hahaha cause i realy beat this bugger up hahaha i know your gonna say the second nut should be up under the other side to hold it up but i found it held the piece tighter this way i had acouple pop out of the clamp so i allways doit this way i even bent the all tread i should look around for some stainless all thread for it ---but here go's ![](http://img.photobucket.com/albums/v115/sandsman1/SELL257A.jpg)
Post by docone31 on Nov 30, 2004 21:11:16 GMT -5
John, you can make one from 1"coreplast. That you can get from Home Depot. You can also bush the inside threads with valve adjusters. All you would have to do is replace the threaded rod. The threads on the valve adjusters on a Gm are 1/4 28. Put the valve adjuster on backwards and you have a round high point. Might give that a try untill you get another one. The valve adjusters can be found in any machine shop, or boneyard.
Post by connrock on Dec 1, 2004 19:26:36 GMT -5
No Doc I'm not a machinest. I'm a self taught wannabe. We have a couple lathes,a Bridgeport milling mach,pretty good size drill press and a surface grinder. You'd be surprised what i've made on just these few machines.Nothing big but a for instance is a master lap,a few vises (different types and sizes,a lot of tumbler shafts,polisher/grinder shafts. The only problem is that I have to stay after work to use the machines so it may take me weeks to get anything that has to be precise done. But in most cases I can get things in a night or two. "Finding" the material is thr hardest thing to do!!If ya know what I mean?? LOL Tom ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Post by connrock on Dec 1, 2004 19:28:28 GMT -5
Yea John it looks pretty beat up there. I still think I can fix ya up though. Mind you now it may take me a week or 2!! Sorry!! Tom ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Post by docone31 on Dec 1, 2004 19:42:44 GMT -5
Tom, I do not care if it takes years. My Raytech is still running. I am just looking to upgrade. The faceter is made with that white plastic used on counters. Most of the pieces are 1". I also like aluminum for faceters. You will find the faceter in Tips. Take a look. If you could do it, even if it takes years, Maybe we can work things out. All I have now is an hand drill, some mechanics tools, and jewelery tools like no one else. I am looking to get a speed increaser for my foredom next.
