wanabe
Member since September 2006
Post by wanabe on Sept 3, 2006 10:52:33 GMT -5
While visiting eastern Canada, we gathered some rocks that we would like to tumble. I have read some of the information on the Rock Tumbling Hobby web page. I would like to give rock tumbling a try but I have no equipment or supplies. Where do I need to shop. I would consider used equipment. I live in the Oklahoma City, OK area.
Post by Cher on Sept 4, 2006 12:40:30 GMT -5
Hi, Welcome to the RTH forums!! One thing really depends on how much you want to spend, you can sometimes get really good deals on used equipment on eBay. I would suggest buying a Lortone or Thumlers, they cost more but last a lifetime. Chicago Electric is ok if you're mechanically inclined as they tend to need fixing quite often. There's been a lot of info ... pro's and con's here on the forum, you can try searching to find more.
Cher
fatrichie
Member since July 2004
Post by fatrichie on Sept 4, 2006 16:32:41 GMT -5
Welcome to the board. hang around here long and you are sure to be tumblin' fool!
Rich
Post by sandsman1 on Sept 24, 2006 7:27:46 GMT -5
welcome wanabe --- start watchin ebay and like cher said its worth the extra few bucks to get a lortone or thumlers
spacegold
Post by spacegold on Sept 28, 2006 3:25:45 GMT -5
Hi, wannabe, and welcome. If all you came to do is stick your toe in the water, beware. This bunch will have you swimming in the surf in no time, and I doubt you could find more helpful and informaive folks.
As for good used equipment, here are the names of a few good six pounders that show up used from time to time
Scott-Murray (I think bought out by Lortone) Star-Diamond Craftool Sears Companion
For anything smaller, I think you would be best advised to stick with Thumlers or Lortone
Grind away........ Spacegold
RockyBlue
Go U.K.
Member since June 2006
Post by RockyBlue on Oct 18, 2006 10:55:50 GMT -5
Welcome! On Board! When i started i bought the Lortone 33b,and 2 extra barrels,so that i would have a barrel for each grit size,60/90.120/220, 500,AO polish i bought them from The Rock Shed,i`m happy with them...Rocky
