Post by connrock on Jan 25, 2005 21:13:18 GMT -5
Post by Tweetiepy on Jan 26, 2005 9:37:08 GMT -5
Hi Connrock,
Thanks for that link. One newbie questions: how do I use this table when tumbling (what does it mean? Anything over a 5 can be tumbled no problem & will take a nice polish?) Sorry for my ignorance it's hereditary.
Rose
Member since November 2004
Post by Rose on Jan 26, 2005 9:52:55 GMT -5
Its a scale of hardness - so if you put something of 7 (quartz) hardness in with something of 4 or 5 (malachite). The malachite would likely get scratched, by the quartz and come out dullish.
Rocks of less than 5 can be tumbled, but with other rocks of similar hardness.
Post by Tweetiepy on Jan 26, 2005 9:59:19 GMT -5
Does it impact whether or not the stone will take a polish or not? I have some stones that were in the rough for only a short time - they were already smooth after that - they're in polish now, but I'm not sure they'll shine up real nice because of that.
Is there a number difference that can be put together? like one number difference (4 & 5) will go together but not two (4 & 6)?
Rose
Post by Rose on Jan 26, 2005 10:01:37 GMT -5
Post by Tweetiepy on Jan 26, 2005 10:09:42 GMT -5
Thanks for your help Rose.
I hope this helps me in my next batch
MichiganRocks
"I wasn't born to follow."
Member since April 2007
Post by MichiganRocks on Jan 26, 2005 17:12:40 GMT -5
Hey Tweetiepy, the time recomendations given are generally for rocks of 6.5 -7.5 hardness. As you drop down in hardness, the time the rocks are left in each sequence will be shorter. In fact, while 6.5 - 7.5 would run for 7 days, I would only run for 4 days with a load of 5.5 - 6.5 rocks. You don't need any more time or work done than is necessary to make the rocks shape like you want. From there, it's just a polish cycle. Softer rocks very suscepible to damage to be sure and use something to cushion them.
Ron
Post by Tweetiepy on Jan 26, 2005 17:59:01 GMT -5
Like I mentioned, I had some rocks that were done in rough after 4 days and I put them in polish a few days ago. I added cut-up pieces of elastics - hopefully that will help them out. I'm anxious to have a look at what I got. (I hafta peek ever 2 days or so - specially in the polish stage - I've been pretty good for the other stages).
Now if I can only get my shipment of mexican lace......
