wades
Gottfried Reiche (1667-1734)
Member since February 2006
Post by wades on May 17, 2006 12:43:02 GMT -5
Somebody recently asked about removing rust stains from rock. Here are some instructions, it sounds straightforward. Mineral Cleaning By John Betts
Post by BAZ on May 21, 2006 20:35:24 GMT -5
I have also used a product from Wink called "Rust Stain Remover" (in a brown bottle) that you can purchase in the laundry aisle. It is pretty nasty stuff according to the bottle though, I always use plenty of water afterwards.
Post by joe on May 24, 2006 0:02:27 GMT -5
I understand that "Iron out" does the job more safely than muriatic acid.
Post by pho on May 24, 2006 8:19:13 GMT -5
Iron out will work on some minor stains. Mostly I use oxalic acid on my tougher jobs. I have had great luck with oxalic and will continue to use it. It is safe to use if one uses common sense. I never use it inside the house or shop...always outside. I also monitor the progress of what I am cleaning. I pays to be safe.
Pho
