blarneystone
Rocks in my head
Member since March 2010
Post by blarneystone on Sept 26, 2006 17:05:16 GMT -5
I bought a well used 10" Lortone flat lap and the pan is pretty crusty....
I've read that the lap pans should be conditioned so that there are fine grooves in the pan to carry grit. I'm thinking that I could use 600 grit sand paper and a small power sander to remove the crusty old crud and resurface the pan.
Does this sound like a good idea? and if not does anyone have any suggestions for reconditioning the pan...?
Thanks! Dan
Post by stoner on Sept 26, 2006 20:14:31 GMT -5
You'd have to be pretty careful to make sure you didn't create a wavy surface. How much are replacement pans from Lortone?
blarneystone
Rocks in my head
Post by blarneystone on Sept 27, 2006 9:42:33 GMT -5
I'm honestly having trouble finding 10" pans online...
Post by sandsman1 on Sept 27, 2006 20:38:49 GMT -5
yea i wouldent use anything that could change the level of the surface inside like ed said maybe id try a power washer and see if it takes off the crude just keep movin it i dont know if it could remove any aluminum there pretty powerfull
blarneystone
Rocks in my head
Post by blarneystone on Sept 28, 2006 10:20:35 GMT -5
Thanks John... My wife suggested the same thing last evening... I'll try the pressure sprayer at the car wash. I may have to buy an oversized polishing pad and cut it down to size because I can't find anything for 10" laps!
Post by Jack ( Yorkshire) on Sept 30, 2006 1:30:58 GMT -5
Hi Dan ,
Ever tried Patio cleaner or brick acid this would remove cement from tools Im told ( this last week) and Lapidary crud is pretty simular.!!
Then Power wash once the crud is loosened.
I havent any further Information (on the brick acid) but I could find them out for you, if you cant find them out .?
Send me a PM or post here .
Jack
Yorkshire UK
Post by connrock on Sept 30, 2006 8:03:34 GMT -5
blarneystone
Rocks in my head
Post by blarneystone on Oct 2, 2006 11:19:10 GMT -5
Thanks Guys,
I'm going to try some calcium, rust, and lyme remover and then take it to the car wash to use the pressure sprayer. Hope that will do it.
Thanks for the link Connrock~ I may have to buy a new one yet!
