Post by lonewolfrockhound on Jan 3, 2007 11:06:53 GMT -5
Dadgummit....I never get good search results. I searched for "saving polish" here and got nothing but I'm SURE it was here that I read that you can let used polish dry out and re-use it?
I poured the polish (Aluminum oxide) out of the barrel and into a clean plastic bowl and it now sits in a cabinet with the water slowly evaporating.
If I do re-use it, do the people here in the know suggest that I use some of the "old" polish and then charge the barrel with a bit of "new" polish for the next tumble?
Thanks in advance! )
Post by cina on Jan 3, 2007 11:26:49 GMT -5
I just put the pellets and polish in a plastic bowl and when I do a new batch I use the old pellets with the polish on them to fill barrel and add a bit of new polish and I am off and running Works good for me hope this helps
Post by lonewolfrockhound on Jan 3, 2007 12:27:33 GMT -5
Yay! Thanks! (it is expensive after all)
Post by akansan on Jan 3, 2007 20:49:02 GMT -5
I normally use only 1 1/2 Tbsp polish. I'll use 1 Tbsp of the old and 1/2 Tbsp of the new. There is someone on here that leaves the polish in the barrel completely - just adds new stones...but I can't remember who!
Post by lonewolfrockhound on Jan 3, 2007 21:30:51 GMT -5
Thank you akansan!
Post by Jack ( Yorkshire) on Jan 4, 2007 4:40:10 GMT -5
Hi I use my old polish continualy just adding a 1/4 to 1/2 teaspoon of new each time,
I dont dry it out just store it in a tall bottle and let it settle and pour of the excess water the remaning thick soup is just about the right consistancy for the polishing cycle
Jack Yorkshire UK
Post by stefan on Jan 22, 2007 12:55:56 GMT -5
I reuse old polish- heck there are times where I don't even add any new stuff to it- I try to keep about 2 tbsp of polish in the barrel- so I really only add new stuff about every 2nd or 3rd run!
Post by Jack ( Yorkshire) on Jan 23, 2007 3:30:06 GMT -5
Hi Stefan, Thats agood idea keeping the polish in the barell dedicated to polishing only.
I suppose you fish out the polished rocks ?
have a good day
jack Yorkshire UK
Post by stefan on Jan 25, 2007 13:51:25 GMT -5
Ummm are you supposed too??? Yea I have a whole little system for my Polish recovery efforts- probably a lot more complicated than it needs to be- but It gives me a good excuse to play in the shop!
