Tellfamily
Member since September 2004
Post by Tellfamily on Feb 2, 2005 22:50:11 GMT -5
How offen do you use a dressing stick on a blade? Does it really need to be done? Where do you get one? Is using an old grinding wheel a good substitution?
Post by sandsman1 on Feb 2, 2005 23:55:24 GMT -5
hi tell you can use a old grinding wheel or what i do is if i have a piece of agate i just take acouple slabs from it and its hard enuff to clean up the blade ive never used a real dressing stick,, iv herd you can allso use a reg red brick and make a couple cuts in it and it will also dress the blade---as far as how often id say if you notice a dif in the way the blades cuttin then try one of the above,, ive never realy noticed a dif in how the blade was cuttin in eather of my saws so iv realy never said ok its time to dress the blade,, like i said every now and then ill cut some agate and i havent had a prob so far
Post by rockyraccoon on Feb 3, 2005 1:38:38 GMT -5
tell i have one that i got from kingsley north and i used it alot. it always helped but the duration of improvement was short lived because i think i had abused the blade pushing the rock too hard. with the new saw i won't be interfering with my pushing so the blade hopefully will do much better ;D.
kim
Post by mrbrett on Feb 3, 2005 15:51:58 GMT -5
On my 20" saw I use a red brick. they say because it is soft and when the blade cuts, the cut material rolls on the blade and resharpens the diamonds. Did that make any sense? Also, the feeder motor on my saw is very slow. A rock that is 8" round might take well over an half an hour to cut threw. Good luck. Brett
Post by connrock on Feb 3, 2005 20:43:43 GMT -5
It also helps to turn your blade around every so often. The diamond gets rounded off slightly so if you turn it around the diamond will have a new face to cut better. Tom
Post by BearCreekLapidary on Feb 3, 2005 21:44:29 GMT -5
Hello TellFamily, Tom gave you some very good advise I will turn my 14" saw blade every six to nine months or so ... and I do a lot of cutting. I do not use dressing sticks or red bricks, as I rarely ever need to dress my blade. I have found that by turning the blade every so often ... the need to dress the blade is no longer an issue. I have probably cut 50 slabs of rock since Monday ... to give you an idea of how much slabbing I generally do. When the weather warms up ... I will be able to slab even more. Enjoy, John
