offbeat
no posts
Member since May 2010
Post by offbeat on Jul 1, 2006 12:13:29 GMT -5
OK, we all know what wonders Borax does in working with our rocks. I was doing laundry yesterday, never ending process, and while I was put to soap in I decided to put in some Borax to see if there would be any difference. Wow!! That stuff really works. I can't believe how much softer and how nice the clothes looked. After 3 more loads I am hooked! Borax will now be a regular routine with the laundry!! Take care, Bill
Post by Toad on Jul 1, 2006 13:02:16 GMT -5
Don't tell my wife that. I don't need my stash disappearing.
Post by gemkoi on Jul 1, 2006 16:56:51 GMT -5
That made me Laugh good offbeat. Just dont be sprinkling it on a bowl of Cheerios in the morning. lol
Post by docone31 on Jul 1, 2006 17:52:14 GMT -5
Did you ever think of packaging and marketing the Borax? It might make a miracle cleaner and jewelery flux. I can see it now, Ronald Reagan, wagon, mules, rowdy cowboys, mad indians, helpless settlers. You could be a borax magnate.
Post by BAZ on Jul 1, 2006 18:56:27 GMT -5
That is funny Bill! Also, you know those Workforce saws? Guess what... they also cut tile! I used mine last week to do the kitchen and all of the bathrooms! Back to serious work yesterday with the saw slabbing rock.
I might just try Borax in the laundry too! Hee hee!
offbeat
no posts
Post by offbeat on Jul 1, 2006 20:48:24 GMT -5
Oh come guys, it really works!! Hee hee! Do you think the originators would believe that the box I have now is probably the 4th or 5th box that I have purchased. This is the very first time I have put any in the wash machine! I figured with our water softener we wouldn't need any add ons. I might have to check to see if the softener is working like it should.
Hey I was also thinking that the plastic beads I have might work well for people that make stuffed animals. They could sew little people and stuff them with the pellets and call them Beady Babies!!!
Ya'll take care, Bill
Post by docone31 on Jul 1, 2006 22:21:26 GMT -5
If you have a water softener, you can add 10% chlorine to the salt mix. It hyperactivates the resin in the bottle. It is commonly found with pool additives. It makes a big difference, and does not harm the softener. Salt, is essentially a chloride.
Post by rockds on Jul 1, 2006 23:00:56 GMT -5
hey bill, ever use borax on your hands, makes them all nice and clean and soft
Post by Alice on Jul 4, 2006 12:51:24 GMT -5
works well in the toilet too
Post by docone31 on Jul 4, 2006 13:58:32 GMT -5
Hey, has anyone considered using Borax as a soap?
Post by Toad on Jul 4, 2006 14:02:12 GMT -5
Isn't it a soap helper? SO if there isn't any soap to help, would it do anything???
Post by docone31 on Jul 4, 2006 14:49:35 GMT -5
It depends on what was actually said.
offbeat
no posts
Post by offbeat on Jul 4, 2006 23:35:23 GMT -5
So if I load 400 pounds of salt in my softner, I would add 40 pounds of bleech or would I use something like pool chlorine? or could I wait until salt level gets low and add at that time? Once more I am confused!
If it is a soap helper it wouldn't have anything to help if you didn't have soap in the mix too??
Post by docone31 on Jul 5, 2006 8:48:08 GMT -5
Pool chlorine helps. I just throw in a few gallons of 10% every once in a while. It definately makes a difference.
offbeat
no posts
Post by offbeat on Jul 5, 2006 22:09:19 GMT -5
I'll give a try at that Doc, thanks!
Post by docone31 on Jul 5, 2006 22:33:18 GMT -5
It worked for me. The well people we had building our water processing plant for our home in Punta Gorda told me of that. I tried it, it worked. If your water smells like rotten eggs, remove the magrod from the water heater. Also common fix for that. A little So2 in the water is good for hair.
offbeat
no posts
Post by offbeat on Jul 6, 2006 0:00:40 GMT -5
I removed the mag rod before I even I fired it up on our water heater when I installed it. My wife kind of gave me one of "those" looks, but after her father told her it was the right thing to do I was back in good graces! I guess it does seem a bit strange to tear things apart and remove parts on brand new things before you use them! I'll give a report back after trying the chlorine trick! Thanks, Bill
Debs
Member since February 2005
Post by Debs on Jul 6, 2006 0:37:36 GMT -5
Isn't that funny, I never think about using if for my laundry or cleaning anything but rocks. I'm going to try it and see how it works! Godd idea offbeat!
