billyd
Member since December 2004
Post by billyd on Feb 7, 2005 8:38:23 GMT -5
hi can anyone help me with a few ? i have made a saw with 8" blade but dont know what rpm to run at will be cutting agates do i run water or cutting oil, if its oil what do i look for. I know i have asked a lot but is anyone daft enough to explane how to work the various parts of the site,i have very little understanding of it. cheer's billy.d
Post by krazydiamond on Feb 7, 2005 9:18:41 GMT -5
i have looked at a lot of the specs for the various saws online and see 1/3 HP motor; 1750 RPM faily consistently. but i don't know what size motor you have Billd and you would be running 220v? so i will defer to the other homemade experts.
you'd probably be better off with oil. i use water and coolant on my 6 inch, but they suggest any larger than 6 and you should use oil. they sell lapidary cutting oil, but some of the members in here attest to using baby oil among other things.
what parts of this site are you having difficulty, Billyd?
we are all here to help,
KD
Post by docone31 on Feb 7, 2005 9:37:41 GMT -5
Billy, you first need to orient the tinfoil hat North, North East. Ok, Running speed for a diamond saw blade is 1750 Krazy is not so crazy there. The motor speed is either posted on the motor, or you can find it from the manufacturer via the web. You will need to step down the blade speed from the motor. Any motor will work. Water is ok, for the blade, but lubrication for the blade and bearings is better. I use baby oil mixed with a little mineral spirits. Straight baby oil is real thick. Some stones also do not like baby oil. Turquoise, malachite, lapis, opal. They absorb the oil. I reccomend a lubrication bath rather than a drip for the lubricant. The blade will last longer. Good for you for making your own. It is what lapidariasts did before corporations stepped in. Homemade, you can make it better. I have also used engine oil. 5W20 for lubricant. It works but has an odor. I use alcohol to wash the stones with some success with turquoise. Great work, keep it up. You can do it.
Post by sandsman1 on Feb 7, 2005 9:46:08 GMT -5
hi billyd try this maybe it will help
billyd
Post by billyd on Feb 7, 2005 13:16:56 GMT -5
you all are brilliant connot praise you enough ;D the moter runs at 1420 rpm the saw spindle is less than 1/2" forgot size help should see the job done & dusted .Waiting for freind to weld bits together as i faild 3 times to get it water tight. that never shocked me as i had never tried before. billyd
Post by docone31 on Feb 7, 2005 14:54:27 GMT -5
The motor runs at 1450? That should be enough for light work, bump it up and get the extra 300rpm for large work, and constant cutting. You can lead solder leaks in a tank. Lead will fill a gap, and the stones are not going to get lead poisoning. I bet you can do it.
billyd
Post by billyd on Feb 7, 2005 20:26:43 GMT -5
cheers d have ground of old one allready will get on to my freind as he should have kent that being a plumber come pipe fitter. The moter is a 1/4 hp and has 3 pully's smallest 1 1/2" largest 3 1/2" will make spindel to take same size as moter can some kind person give me maths numbers to work it out. On to how to use the site better. when posting reply to say thanks to someone and nobody answers for a while do i start a new thread or can i add new question on? billy.d how thick a slice do i take of my stones, how thick a blade is best to stop me bending it,if i do can i straighten the blade again, ta will have new saw running by next weekend will try and post some pic's it wont be very bonny as it is made from old metal and wont be painted (lucky it) i paint worse than i weld. billyd
