Post by creativeminded on Feb 9, 2005 8:37:30 GMT -5
I have a question. What is the ratio of saw blade size and the thickness of rock? Meaning what is the maximum rock thickness can I put in say a 10" saw blade? Tami
Post by docone31 on Feb 9, 2005 8:46:22 GMT -5
As long as the blade can emerge from the stone during cutting, you should not fry the blade. A blade needs to have at least windows to clear debris from the cut kerf. I do not reccomend full depth cutting unless it is the only way.
Post by rockyraccoon on Feb 9, 2005 8:49:04 GMT -5
tami i was told that you can go around 1/3 of the blade size so for a 10" blade you would want to stay around 3 to 3-1/2" on the rock size.
kim
Post by creativeminded on Feb 10, 2005 9:16:03 GMT -5
Thank you for the info. Tami
