Post by Tweetiepy on Feb 11, 2005 8:37:10 GMT -5
Does anyone know if the pieces of tumbling rock need to be 1" max?? I've received 4 lbs of rock and some pieces are bigger than that, they're all relatively close in size, but I don't have the 1/2" - 3/4" pieces like the book states. Mine are more like 2" x 1" some are smaller but they're mostly much more than the 3/4"
Can I tumble these no problem in a 33B?
Post by stefan on Feb 11, 2005 9:07:46 GMT -5
My thumblers 3 lb barrel recommends nothing over an inch and a half- On the larger stuff I either crack it with a hammer and chisel or save it for when I get a bigger tumbler (or my saw) THere is a project on here involving a large rock that was run with smaller stuff for several cycles- Kinda like a filler stone for 3 or 4 loads- Keep in mind if the rock can't move FREELY in the barrel- it ain't gonna shine!
stubby
Member since April 2004
Post by stubby on Feb 11, 2005 9:13:25 GMT -5
tweetie,
I have run as big as a single 2 1/2 incher in my 33b. You must have the rest of the load as small stuff to keep it moving. I had decent sucess. And as the stone gets smaller, it is less of a problem.
stub
Post by Tweetiepy on Feb 11, 2005 10:08:36 GMT -5
The thing is, all the rocks that came in my package are wonderful as is. The biggest are 2x1x1/4" - Some are smaller like 1/2x3/4 or 1/4x1/2. I'd hate to just stick one biggy with all the rest being tiny pieces (that I'd have to split up). I'd hate to split some up ![:'(](//storage.proboards.com/forum/images/smiley/cry.png) - maybe the less pretty ones could be split, but the bigger ones are really beautiful & banded & I'm drooling over them as is! ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) I guess I'd have to do a wet run with just water & rocks to see if they seem to move around okay - I may have to just mix & match them to see what tumbles okay together and then load up
Post by Cher on Feb 11, 2005 11:18:56 GMT -5
Grab some smaller (1/2 inch to 1 inch) driveway rocks to toss in as filler so you can tumbler the bigger pieces, then you won't have to break up the pretty stuff.
Cher
Post by Tweetiepy on Feb 11, 2005 11:49:21 GMT -5
Could I as well use some of my previous tumbling attempts to use as filler even though they're kinda shiny?
Post by stefan on Feb 11, 2005 12:11:20 GMT -5
MOST DEFINATLY- That is what do overs are for
chassroc
Post by chassroc on Feb 11, 2005 12:28:39 GMT -5
A couple of 2 inchers per load would not hurt...I think things just need to be able to move a bit, grinding and crashing as violently as possible without shattering in the early stages
Post by Tweetiepy on Feb 12, 2005 11:55:03 GMT -5
I ended up having to crack apart some of the less pretty stones to make smaller pieces otherwise I would have had to have about 20 loads to polish up what I got with my tumbler - I'm all excited now!!!!
