Post by LCARS on Nov 16, 2006 0:16:07 GMT -5
WARNINGDO NOT ATTEMPT THIS! IT WILL INVITE YOU IT WILL TEASE YOU IT WILL HAUNT YOU IT WILL CONSUME YOU
[/color][/size] TURN BACK NOW![/color] You have been warned... www.draculasriddle.co.uk/I started this yesterday and I have now reached 13 as of this post. It is too late for me but you can still save yourself if you stay away.
Post by Tweetiepy on Nov 16, 2006 12:13:29 GMT -5
I got the first one...... still thinking on #2..... this may take a while...
Post by pho on Nov 16, 2006 12:48:13 GMT -5
I'm with Tweetiepy....stuck on the second page. Any clues? I highlighted the words at the bottom of the page and see the words "are yet the" in the blank space but have no clue what it means..
Pho
Post by Tweetiepy on Nov 16, 2006 15:41:33 GMT -5
Pho I got sucked it, the forums have many clues, I registered up & gave LCARS a blast for sucking me in!!! - very addictive..
Post by pho on Nov 16, 2006 17:29:22 GMT -5
well I must be dumber than a box of rocks because I do not get the answer. I see the words but it still means nothing to me.... Pho
Post by krazydiamond on Nov 16, 2006 17:41:34 GMT -5
well, i'm even dumber than that, i can't even figure how to get it started...DOH!
KD
Post by LCARS on Nov 16, 2006 19:46:32 GMT -5
Some people just never listen. I told you all to STAY AWAY! Now your fates are sealed... KD, what's happening? I know it works fine with MIE on a Windows machine, are you running something else? Read the entire first riddle which gives some instructions on how it works. If you right click on the black part of any page you can select "view source" which will display the markup text used to generat the page. It very often contains some hidden text, a reference to a secret file, or info & hints on solving the riddles. You simply type the correct answer to teh current riddle in place of "whatever".htm at the end of the URL to advance to the next one. The URL is redirected automatically when you move to a new area and the riddle number is displayed in the source text because some riddles have multiple parts. Read the forums if you are having trouble or post here and I will help. I recommend creating a DR folder in your Favorites and bookmark every single page you end up on because you may have to revisit a previous riddle to solve the one you're on. It's already happened to me once. I figured most of it out on my own so far but there was a few that I had to look to the forums for hints on after spending awhile unsuccesfully trying to solve it. Sometimes you are just thinking about it the wrong way and a hint can get you on the right track without spoiling it but other times you just have to Google the hell out of it until you learn enough to divine the answer from the context. It's really quite addicting. Tweet, Pho, keep at it because the more you get into it the easier it is to anticipate what you need to do to solve each riddle. God help us all, there's over 80 riddles to solve before facing Dracula himself!
Post by LCARS on Nov 16, 2006 22:47:05 GMT -5
I'm with Tweetiepy....stuck on the second page. Any clues? I highlighted the words at the bottom of the page and see the words "are yet the" in the blank space but have no clue what it means.. Pho Pho, "are" "yet" & "the" are the useless words. Read the source for a clue on what to do...
Post by akansan on Nov 17, 2006 0:03:26 GMT -5
Okay, LCARS - it's definitely your fault. I'm plotting numbers and coming up with nonsense, so I'm blaming you. Page 6 is killing me! Okay, nevermind. Makes sense when you can spell...
Post by Tweetiepy on Nov 17, 2006 8:42:37 GMT -5
I'm on 6 and wondering around aimlessly, I can't even get to the next image....
Post by akansan on Nov 17, 2006 9:04:16 GMT -5
Tweety, on this one you have to look at the view source to get anywhere.
Post by Tweetiepy on Nov 17, 2006 11:02:23 GMT -5
Akansan, 1: I can't get source code on the imaginary image A nor B (is this normal?) 2: found the second image, plotted out the words & I get "what am I?" yes indeed, what is it? tried many word combinations & still can't find the right words to get to the 7th riddle...
Post by akansan on Nov 17, 2006 11:52:20 GMT -5
AH! That's where you are!
Take a look at the way the letters are written for the title on that page. What is THAT?
Post by xenaswolf on Nov 17, 2006 12:37:05 GMT -5
Ok stuck on page 2....all the words are uselsess as far as I can tell LOL
Post by Tweetiepy on Nov 17, 2006 12:45:03 GMT -5
Akansan set you a PM
Xena, on the site they have a forum for answering questions - and if you search the web with that question, you can find a forum where they give hints and answers in a roundabout way...
Post by LCARS on Nov 17, 2006 13:43:22 GMT -5
Ok stuck on page 2....all the words are uselsess as far as I can tell LOL The clue to solving that one is in the source hint at the bottom. Remove "are" yet" & "the" from the photo text then use the hint in the source at the bottom and see if it makes any sense. Alot of times you have to plot things out on paper or a word processor to mess with. Always keep things in the same format as you see them. I almost missed one because I didn't keep the format when I was working. Don't forget, many of these are devious and clever. Some are deeper than what's on the surface and others are simpler than they seem. Assume nothing. Oh-ya, source text is only available when viewing the .HTM files so it's normal not to have any when it's a .JPG.
Post by LCARS on Nov 17, 2006 13:47:12 GMT -5
Here's a hint for #6 Tweet
Have a look at the answer you got and note that it has a unique characteristic about it. The unique characteristic of the answer you got is the actual anwser to the riddle and why it asks you "What am I?" if you just type in the answer. Get used to having to interpret an answer in order the find the "real" answer to the riddle. If asked a question(s) always answer. If it's not the right answer to the riddle it may lead to additional info/hints or directions on how to get it.
Post by LCARS on Nov 18, 2006 1:52:20 GMT -5
OK, time to get those skeletons out of the closet. Who's playing and how far have you got so far? I'm at 16 right now until I figure out what to do with what I have so far... EDIT: I just had a revelation, make that 18 now.
Post by Tweetiepy on Nov 18, 2006 9:48:18 GMT -5
I'm on the one with the 9 clues - sorry can,t remember which number - but I've put it on hold so I can eat & sleep a bit!
Post by pho on Nov 18, 2006 10:05:34 GMT -5
I made it to page three....and quit. Got too many other things I need to be doing.
Pho
