JKowalski33
Member since August 2004
Post by JKowalski33 on Feb 13, 2005 15:46:55 GMT -5
I just got an older model thumler off ebay. It is a model A-1, and its just a single 6lb barrel tumbler. the lid just slides in place, and isnt that snug. I also found out that it is not water tight. So my question is, what can I do to make the lid water tight?
Post by sandsman1 on Feb 13, 2005 16:26:30 GMT -5
i think you can get a new seal ring for it maybe the ring is worn or dried out
Banjocreek
Member since March 2003
Post by Banjocreek on Feb 13, 2005 16:31:27 GMT -5
Did you even GET the 'O' ring that goes around the lip on top to hold the lid on?
JKowalski33
Post by JKowalski33 on Feb 13, 2005 16:36:24 GMT -5
no i guess not, I didnt realize that one was needed, I have never owned a thumlers before. I guess thats what i'll have to get
JKowalski33
Post by JKowalski33 on Feb 13, 2005 19:33:09 GMT -5
by the way, does anyone know where i can order an o-ring for a thumlers 6lb barrel? I cant find one anywhere
Blue Tigereye
Post by Blue Tigereye on Feb 13, 2005 19:46:38 GMT -5
The thumler A-2 I just dug out of my garage didn't come with an O ring. I think it is about the same as an A-1, it just holds 2 3lb barrels. A Lortone 4lb barrel works just fine on it too which is what I am running on it now.
Post by hermatite on Feb 13, 2005 20:11:26 GMT -5
I run with thumlers barrels...you can get replacement lids and o-rings at the rockshed. The lids are two bucks and the o-rings $2.50 a pop. Not bad considering I've only ever had to replace one O ring and that was because the cat chewed half way through it.
JKowalski33
Post by JKowalski33 on Feb 13, 2005 21:18:34 GMT -5
i looked at the rockshed, but i didnt see any parts for 6lb barrels.
Post by hermatite on Feb 14, 2005 9:16:11 GMT -5
Well smack my pointy head, sorry about that, I could have sworn I saw them. I use three pounders and well...duh...sorry.
Post by sandsman1 on Feb 14, 2005 9:34:10 GMT -5
jk email them ask if they can order one they prob can or just email thumlers im sure they can send one out
Eric
if you build it and they dont come, your screwed
Post by Eric on Feb 14, 2005 11:04:47 GMT -5
JK... either the rock shed or thumlers web site have the lids and o rings available. i thought they had them at the rock shed though. cuz i just got 2 new barrels and the lids were just beneth them. good luck!!! as for the water tight seal...on my A-2 the seal isnt really water tight...a small bead of water comes out the side but doesnt drip or anything...just goes around with the barrel, but i can see and even wipe the water from around the rim. no big deal in my book
stubby
Member since April 2004
Post by stubby on Feb 14, 2005 11:13:42 GMT -5
Try a good auto parts store. Take the barrel and have them match an O - ring. I have done this for rings and belts.
Eric
Post by Eric on Feb 14, 2005 12:36:11 GMT -5
just checked the rock sheds web site...follow this link and scroll to almost the bottom...there is a section for parts, lids etc. www.therockshed.com/tumbler2.htmlhappy tumbling!!!
