Post by cpdad on Dec 7, 2006 22:11:48 GMT -5
anybody done something like this before?...son came to me this evening and said dad its due in 2 weeks...but we should have started 4 weeks ago...i forgot about it he brought me this. www.yesmag.bc.ca/projects/crystal_gardens.htmland after scrambling this evening to find a little more info i found this www.beloit.edu/~SEPM/Rocks_and_minerals/growing_crystals.htmlwe can make this work im sure..but has anyone done it...and can add any advice on what to look out for?..what to change..any info at all...he has 2 weeks to make something work...thanks.
Post by docone31 on Dec 7, 2006 22:38:41 GMT -5
Hehehe, typical kid. I have done the first one. The second one was a dud. The first one is pretty quick on growing. He might have some results in two weeks. The second one takes a long time. Good luck, mine is grown and dumb and dumber. He is 31, and thinks I am still in alaska. I have been trying to get him down to Floriduh to teach him diamond setting. He has no clue whatsoever. Oh well. Good luck to the two of you. It should be interesting.
spikeict
Alba gu bra! In Promptu
Member since November 2006
Post by spikeict on Dec 7, 2006 23:00:49 GMT -5
I wish this had come up yesterday before 6pm cst. The program "good eats" on the food network explained crystals very well in a segment about fudge. I don't even want to try to go step by step for fear i wouldn't remember right, but perhaps someone has it on dvd? Maybe some of the info wouls help.
Post by joe on Dec 7, 2006 23:35:50 GMT -5
I did that, and it works. Start it soon if you want results in two weeks. Set everything on top of newspaper because this experiment will "grow" right over the side of the containment bowl! I'm not too sure that the end result is portable, it may collapse on the way to the classroom. Hopefully someone else knows more. You can do the second one, the Alum crystals, without the seed crystal. Just supersaturate (add to boiling water until you can add no more) water with Alum OR sodium chloride crystals. Pour the mix into a shallow pie pan so it evaporates quick. The slower it evaporates the bigger the crystals but you guys only have two weeks so a shallow pan it is! When it dries the crystal will be hard. Just don't get them wet or they will dissolve. Good luck!
