Palm?
Feb 26, 2007 19:43:36 GMT -5
Post by beefjello on Feb 26, 2007 19:43:36 GMT -5
I found this and a few similar pieces in an area know to have pet palm bog. After cutting it I_think that's what it is, but I'm not completely certain. What do you think? Thanks!
Palm?
Feb 26, 2007 20:13:03 GMT -5
Post by Sabre52 on Feb 26, 2007 20:13:03 GMT -5
Wow! Kinda has that palm fiber look but the distribution and size of the vascular bundles doesn't look regular enough to be palm. I'd guess it's not palm. We have lots of palm bog here in california too but in that case the rootlets meander through the fossil mud and the saw cut catches them in many places and directions giving them more the look of tubes and eyes etc. Maybe though, there's always atypical examples....mel
desertdweller
Member since August 2006
Palm?
Feb 26, 2007 20:30:30 GMT -5
Post by desertdweller on Feb 26, 2007 20:30:30 GMT -5
The palm found here in AZ looks different than regular petrified wood, I will take a picture of the stuff I have found anyway and show you what it looks like. When are you going out again? Lets get together and do a quick trip close by.
rollingstone
Member since July 2009
Palm?
Feb 27, 2007 2:57:25 GMT -5
Post by rollingstone on Feb 27, 2007 2:57:25 GMT -5
I agree with Mel, it doesn't look like palm bog, and while it does kind of resemble petrified palm wood, the vascular pattern looks much too sparse to be real palm. Could be some kind of unusual fossilization, but I don't think so. Here's a pic of a chunk of palm wood I have, showing the typical vascular bundle distribution you get on palm wood, when sliced perpindicular to the vascular bundles. -Don Here's another way you can check -- if you slice the stone at 90 degrees to the "dot pattern" of the vascular bundles, you should end with this kind of tube pattern if it is real palm wood.
Palm?
Feb 27, 2007 9:00:19 GMT -5
Post by beefjello on Feb 27, 2007 9:00:19 GMT -5
Thanks guys. I have a couple other 'maybes' from that area, I guess I'll know when I cut them. Thanks for the pix Don! Ok so the dif between palm bog and palm wood is that bog is roots? Is that right? Thanks again!
Palm?
Feb 27, 2007 11:36:03 GMT -5
Post by Sabre52 on Feb 27, 2007 11:36:03 GMT -5
beef: What we call palm bog out here is sort of silicified mud with palm roots, rootlets and vegetation fragments strewn through it in various concentrations. When the roots are really large and well distributed, we just call it palm root and the fiber is actual above ground trunk sections or chunks...mel
Palm?
Feb 27, 2007 12:52:57 GMT -5
Post by stefan on Feb 27, 2007 12:52:57 GMT -5
Also when your cutting it it has a distinct smell- almost a sulphery smell- There is no mistaking the smell of cutting Pet wood! Based on the Pix I'm saying no to palm- but a posibility to some other type of wood?
wm7734
wheres my rockhammer ?
Member since January 2007
Palm?
Mar 10, 2007 3:18:14 GMT -5
Post by wm7734 on Mar 10, 2007 3:18:14 GMT -5
got any slab forsale
